Vector V150 INF: new case from Lian Li
Lian Li announces a new case with its Vector V150 INF. This new reference benefits not only from an affordable price, but also from an infinite depth lighting system on the front panel. While the front panel is made of tempered glass, the case features openings dedicated to two large fans, as well as mesh grilles to limit dust infiltration. Last but not least, the price is perfectly affordable.
Vector V150 INF: a glass front panel that still breathes!
A case compatible with BTF micro-ATX motherboards!
Lian Li Vector V150 INF
In terms of dimensions, Lian Li’s case measures 221.5 (W) x 470 (D) x 443.9 (H) mm. Weighing in at 8.1 kg, it’s not the heaviest case we’ve ever dealt with.
Internally, it’s compatible with motherboards up to micro-ATX format. Of course, mini-ITX and inverted connector models are also supported.
As for the graphics card, at 400 mm in length (with integrated support), there’s not much to worry about in terms of compatibility with this component. The same goes for the CPU ventirad: 163.5 mm, which leaves plenty of room for many references on the market. Finally, we find compatibility with 200 mm deep power supplies.
Ventilation :
By default, the case comes with three fans installed, two 140 mm fans on the front and one 120 mm fan on the rear. But up to seven 120 mm fans can be added: two on the power supply cover, two on the side of the motherboard and three at the top. As for watercooling radiators, 360 mm models are supported. As for management, everything is entrusted to a dedicated controller driven by L-Connect 3 software for lighting and speed management.
An affordable bill:
Here, the bill will be affordable, since we’re talking about a selling price of €84.90. At the same time, it’s important to bear in mind that this is a micro-ATX box. It’s not uncommon for prices to be lower than those of mid-tower models.
Here’s the Lian Li product sheet!
