Lian Li announces Vector V100 enclosure
Lian Li announces a new case reference with the Vector V100. On the program, we find a medium-tower model that is quite classic on paper. What’s more, it comes at a rather affordable price, especially without a fan.
Vector V100: an inexpensive reference, especially without fans!
Lian Li Vector V100This is a mid-tower reference with dimensions of 235.5 (W) x 466 (D) x 484.65 (H) mm. As you can see, this model adopts an aquarium style with its front and side windows. We’re also impressed by the particular shape of the power supply cover, followed by the side panel. Internally, we find a motherboard tray with the necessary openings to make it compatible with back-connect models. Otherwise, compatibility with E-ATX and ATX models is assured. As for the graphics card, we have 415 mm of clearance lengthwise, while the ventirad is 180 mm high. In terms of cooling, we have a total of nine 120 mm fan slots. In 140 mm, there are obviously fewer, with three dedicated slots. As for watercooling, the radiator support stops at 280/360 mm at the top. In short, we’re clearly dealing with an entry-level reference in terms of these compatibilities. In addition, this is a case that features a number of cabling aids. These take the form of Velcro strips scattered here and there on the back of the motherboard tray. For graphics cards, a support system is present, while the case features a small platform on the front for displaying your favorite figurine! As for prices, they’re cheap, since without fans, you’ll have to reckon with $59.99 against $74.99 with four mills.
Here’s the Lian Li product sheet!
