Thermaltake completes its ToughPower PF1 TT Premium power supply series by adding two new power ratings. This time, we’re going to look for the high power side with 1050W and 1200W models.
ToughPower PF1 TT Premium: up to 1200W of power in an ultra-compact format!
The Asian brand announces two new power supplies for its series. These last ones show important powers since it is question of block of 1050W and 1200W. However, what is even more impressive is the compact format that they display: ATX in 14 cm depth! Otherwise, we find the “typical” configuration of high-end power supplies with 80+ Platinum certification and a fully modular cable management. Inside, the cooling is entrusted to a fan with high static pressure. The latter will be able to operate in semi-passive mode while being able to reach 2500 RPM at full speed. As for the electrical part, the brand announces to use Japanese capacitors. Also, we can count on a noise lower than 30 mV on the voltages as well as a strict regulation of these last ones <±2% of variation. Finally, we will find a single 12V rail. Concerning the pricing, it is worth what it is worth, nevertheless, we find the 1200W version on sale on a Thai shop at 8290 baht, or about 225 € after conversion.
Thermaltake ‘s data sheets are here!
