TK5M: a Sharkoon airflow oriented housing designed to be seen!
Sharkoon proposes a new case with its TK5M RGB. It is a new model with a medium tower format focusing on the airflow with its mesh front panel. We can also count on an RGB lighting via the fans provided in base.
TK5M RGB: more RGB cases!
Sharkoon TK5M RGBThis model follows the current trend of the manufacturers to propose airflow oriented cases. Indeed, this model comes with a good amount of basic fans and a mesh front. From the beginning, this reference offers four 120mm mills with aRGB lighting.
Apart from that, we find a rather classic case with a glass side panel and a power supply cover. For storage, up to five 2.5″ units or three 2.5″ and two 3.5″ units can be installed in an HDD cage positioned under the power tunnel.
For the rest of the components, we have room for an ATX motherboard. The CPU cooling unit should not exceed 157 mm in height. The graphics card is limited to 335 mm (without front fans, 310 mm with). Finally, for the power supply, it will not exceed 175 mm in depth.
Sharkoon TK5M RGB
Finally, despite a somewhat limited height for the CPU fan, this model will be interesting for its price of 69 €. Moreover, we will remember its compactness since it measures 200 (W) x 411 (D) x 456 (H) mm.
Here is the technical sheet of Sharkoon!
