Asus launches new fans focusing, this time, on its TUF Gaming series. Indeed, the brand offers its TF120 ARGB mills, a bright model with a look faithful to the TUF series.
TF120 ARGB : fans with the effigy of the TUF series !
With its new mill, the brand offers us a fan with a frame rather worked with forms in the effigy of the series. Speaking of the frame, you should know that there are rubber silentblocks at the corners to reduce vibration. We finish by mentioning the presence of a light at the central hub.
On the characteristics side, we have a fan that takes advantage of a PWM type power supply. As for the operating speed, we find a reference that can turn up to 1900 RPM. At full speed, the airflow will reach 76 CFM and the static pressure will rise to 2.5 mmH2O.
In terms of price, this model is sold for €15.90 per unit and €49.90 in a pack of three fans. Note also that we will find a multi-function controller to manage the lighting of four mills. However, it will only be provided with the pack of three.
This way to the Asus datasheet!
