New fan at Antec who launches its Storm 120, a new model focused on performance according to the brand. And unlike its Fusion 120 aRGBthis new ref does not include the RGB!
Storm 120: a high performance fan without RGB!
On the program, the brand announces a new fan with a standard format of 120 mm x 25 mm. Each mill also comes with eight rubber silentblocks on the frame to limit vibrations. And on the connectivity side, we find a double PWM plug, one male and a second female. The goal is to connect the mills in series. Finally, we will notice the width of the seven blades present on the mill.
In terms of features, Antec announces a fairly wide rotation range between 600 RPM and 2000 RPM. At full speed, the fan will generate an airflow of 66.56 CFM and a static pressure of 2.7 mmH2O.
For the time being, the sales prices are not yet known, unlike the 3-year warranty. On the other hand, we know that they will be proposed with the unit, in pack of two, three or five. Ideal to fill a case in one go.
