SP750 White: a white version of the Lian Li power supply!
Do you remember the SP750 from Lian Li? It was basically a 750W SFX power supply with a fully modular design. Well, you should now know that it comes in white. The brand has just announced its SP750 White!
SP750 White: the white version is coming!
Lian Li SP750 WhiteWith this new reference, the brand announces a small format power supply, normal, we are facing a SFX block. At the same time, we will remember its power: 750W, enough to feed rather muscular configurations … All this, with a good performance since it is certified 80+ Gold!
Of course, the cable management (sheathed strand by strand) is fully modular and we have :
  • 1x ATX 24 pins
  • 2x EPS12V 8 pins
  • 3x PCIe 6+2 pins
  • 8x SATA
  • 4x Molex
This is more than enough connectivity, even for large graphics cards with triple PCIe connectivity.
Internally, we find a small 92 mm fan with semi-passive operation for cooling. The choice of components is also qualitative with 100% Japanese capacitors. We also have the right to an active PFC (90% under full load) and a single 12V rail. Finally, as for the electrical protections, we find the OCP, the OPP, the UVP, the OVP, the OTP and the SCP.
For the price, no change compared to the black version: 129,90 € at Caseking.de.
This way to the Lian Li data sheet!
