Akasa launches new fans with its Soho AR Dawn Edition. On the program, we find 120 mm mills with aRGB lighting in the form of fine lines. Let’s see what they offer.
Soho AR Dawn: up to 2000 RPM for the Akasa fans!
With its fans, the brand announces models in 120 x 25 mm, the standard format. The frame has a square shape and has silent blocks to reduce vibration during operation. Likewise, we will not miss the two aRGB borders of the latter or the elongated and curved blades.
Of course, this model is powered via PWM and offers a rotation range between 500 RPM and 2000 RPM. At full speed, it will generate a static pressure of 1.75 mmH2O and an airflow of 52.91 CFM. Akasa intends its fan to be used on cases, heatsinks and watercooling radiators, a versatile model according to the manufacturer.
Finally, we end with the selling price which is 19.95 € in white and by unit. You should also know that a black version is offered individually or in a pack of three. However, no pack for this white color, too bad.
Here is Akasa’s technical sheet!
