Sapphire announces a new graphics card with its RX 6400 Pulse. Contrary to the last CG released, this model is clearly a stain and for good reason. The brand announces a low profile and single slot model! So, making small cards is still possible!
RX 6400 Pulse: towards a return of compact cards?
With this new card, the Sapphire brand announces an ultra compact model. As you can see, this is a single slot and low profile model. Moreover, in the box, you will find a “full height” bracket allowing you to install the card in any case.
Of course, considering the format, the heatsink will be very basic. We find a simple aluminum block in which are machined fins. On the top, a very small fan is present for cooling. We are far from the model Challenger ITX of ASRock for example.
In terms of frequency, this model displays a boost to 2321 MHz, the base frequency. The 4 GB of GDDR6 will run at 16 Gbps.
Finally, the connectivity remains very basic with an HDMI and DisplayPort output. Moreover, given the low power consumption of the GPU, there will be no need for an auxiliary connector for power.
Concerning the price, it will be necessary to spend some 210 € to215 € on the LDLC group stores.
This way to the Sapphire datasheet!
