RTX 4090 iChill Black : collab between Arctic and Inno3D !
Arctic and Inno3D collaborate to offer a new graphics card. The card in question is the RTX 4090 iChill Black, a card cooled by an original Arctic kit. It looks promising!
RTX 4090 iChill Black: Arctic cooling for the Inno3D card!
Inno3D RTX 4090 iChill Black With this card, we find a rather compact model thanks to its double slot format and its limited length of 280 mm. On the other hand, you’ll have to make do with a 240mm watercooling radiator. Nevertheless, remember that this is an Arctic base and the whole thing will be particularly thick: 38 mm + 25 mm fans!
For the cooling, we find a custom waterblock with a large copper base. The latter will cover the memory and the GPU. On the other hand, from what we can see, the pump is eccentric, that is to say that it is placed towards the back of the fairing rather than being positioned on the GPU.
Inno3D RTX 4090 iChill Black refroidissement The ventilation is therefore provided by a duo of P12 aRGB fans. The silence will be part of the game.
On the frequency side, we can count on a factory overclocking. The card will work at 2235 MHz and will reach 2580 MHz in boost. As a reminder, the basic frequencies are 2235 MHz against 2520 MHz in boost.
For the moment, no price is known.
This way to Inno3D ‘s datasheet!
