New case model to appear at our friends from Galax. The brand announces its Revolution-05, a new compact model with a mesh front panel. Let’s see what it offers!
Revolution-05 : a new case from Galax !
First of all, it has compact dimensions with 205 (W) x 400,6 (D) x 481,5 (H) mm. As for the weight, it will clearly not be heavy for a medium tower steel model since it displays only 4.3 kg. This implies the use of thin steel sheets for the construction.
Internally, there will be enough room to install a motherboard in ATX format at most. For the CPU fans, there is a space of 160 mm against 330 mm for the graphics card. If we don’t have any information about the power supply, we know that at the back, we only have 18 mm to pass the cables.
For the storage, we stay on something quite classic with three slots in 2.5″ against two 3.5″.
On the cooling side, we stay on something very classic too with eight fan slots in 120 mm or four 140 mm. For the watercooling radiator, it will be necessary to be satisfied with support in 360/280 mm at most.
On the other hand, we do not yet know the selling price.
Here is the technical sheet of Galax !
