Review: PALIT RTX 5060 Ti Infinity 3 16 GB
[nextpage title=”Introduction:”]
Although we’ve already had our hands on PALIT graphics cards in the past, this is the first time we’re offering you a test of one of their models on our site, with this example of the PALIT RTX 5060 Ti Infinity 3 in 16 GB version. We’ll specify the amount of memory, because as was the case with the RTX 4060 Ti, there will be 8 GB and 16 GB versions. The model we are testing today has an MSRP of 449 euros and will only be sold in a ‘custom’ version, meaning that there will be no Founders Edition models, as was already the case for the RTX 5070 Ti. The 8 GB version, which NVIDIA seems to have left out of today’s tests, will be available at 399 euros. The RTX 4060 Ti 16 GB was launched at €549.
Today we’ll be testing two other cards, with a copy of the MSI Gaming Trio RTX 5060 Ti 16GB and the ASUS TUF Gaming RTX 5060 Ti 16 GB. Before starting our test, the question arose as to which definition to choose for our various benchmarks, since the RTX 4060 Ti is already one of the best choices for enjoying 1080p, and there’s no doubt that this new generation will deliver even greater performance. So we’ll be testing 1080p and 1440p for rasterisation, and only 1440p for ray tracing and upscaling , to see if the latter can go the distance.
Thanks to NVIDIA France for making this copy of the PALIT RTX 5060 Ti Infinity 3 16 GB available.
[nextpage title=”PALIT RTX 5060 Ti Infinity 3 :”]
Architecture :
As a reminder, this PALIT RTX 5060 Ti Infinity 3 16 GB is a custom model , in other words, a card offered by an NVIDIA partner and which benefits from a PCB and cooling system specific to the brand, in our case it is therefore a PCB designed by PALIT. NVIDIA ‘s partners offer their own models. As usual, NVIDIA will not be offering Founders Edition versions of ‘Ti’ models.
This NVIDIA RTX 5060 Ti benefits from the Blackwell architecture and retains a 4-nanometre engraving finesse, but switches to the TSMC N4P process, resulting in greater transistor density and improved energy efficiency. This architecture features new 5th generation Tensor Cores and 4th generation Ray Tracing Cores. The 5th generation Tensor Cores will provide support for the FP4 (Floating Point 4 bits) format, which will double the computational performance of neural models while halving the memory footprint. We’ll be coming back to this development during our tests, in particular with the UL Procyon software that we’ve been using for several weeks now.
Of course, DLSS 4 support cannot be overlooked. This new RTX 5060 Ti is equipped with 4608 CUDA Cores, compared with 6144 for the RTX 5070 version.
There’s also something new on the memory front, with 16GB of GDDR7 memory (448 GB/s). As for the TDP, it’s announced at 180 watts, and NVIDIA recommends a 600 watt power supply. But let’s move on to the new packaging for this PALIT RTX 5060 Ti Infinity 3 16 GB series.
The PALIT RTX 5060 Ti Infinity 3 bundle:
This is an entry-level graphics card, with an MSRP of 449 euros. The bundle is limited to a sheet of brand stickers and is notable for the absence of a power cable adapter. Indeed, as we’re about to discover, this RTX 5060 Ti Infinity 3 model doesn’t have a 12V-2×6 power connector, but rather a traditional 8-pin one. And what if this set it apart from the competition?
The box follows the dresscode we’re used to seeing on NVIDIA cards, with the name of the series on the bottom right, in this case GeForce RTX 5060 Ti in green and black. On the rear panel, PALIT highlights its ‘SFF-Ready’ compatibility. This means it can be inserted into a case compatible with the Small Form Factor for anyone who decides to design a compact configuration.
The cooling system :
The PALIT RTX 5060 Ti Infinity 3 features a cooling system consisting of three 80 mm fans with nine blades. The design of this Infinity 3 model is very sober and does without RGB backlighting. The black plastic casing will match any motherboard and any case. It’s understated and versatile, just the way we like it.
At the rear is an imposing backplate, still made of plastic, whose role is to stiffen the card. The PCB is much shorter than the heatsink and stops at the power connector. As you can see, the hot air escapes through the top edge of the board, through the bracket, but also through the backplate, which is cut out at the end.
We’ll be judging the temperatures and performance of the cooling system during our tests. In terms of thickness, our sample occupies 2 slots and we know that PALIT plans to offer a DUAL version, with two fans, for its model equipped with 8 GB.
Connectors :
To power this model, and this is excellent news, PALIT has chosen to use a single 8-pin power connector.
On the video front, there are three DisplayPort 2.1b and one HDMI 2.1b.
[nextpage title=”Full of new technologies:”]
DLSS4: what’s new?
Deep Learning Super Sampling combined with Multi Frame Generation (MFG). As a reminder, the Blackwell architecture features new 5th generation Tensor Cores and 4th generation Ray Tracing Cores. It is these hardware innovations from Blackwell and DLSS that will enable MFG, which would have been technically impossible on the previous generation ADA Lovelace.
According to NVIDIA, Multi Frame Generation will deliver up to 8 times better performance in games such as Cyberpunk 2077 compared with raw image rendering. Up to 15 of the 16 pixels per frame are generated by the AI. It will also be possible to reach 240 FPS in 4K ray tracing, and to use path tracing in compatible games.
NVIDIA introduit le DLSS 4 avec les RTX 5000
So what will this new generation bring compared with the previous one? The main difference lies in Frame Generation. Whereas with the RTX 4000, DLSS 3 was able to insert an additional frame between two native frames, DLSS 4 will be able to insert up to three, hence the addition of the term Multi FG. This means you can choose to generate a single image (x2) for the RTX 40 and RTX 50 series, two images (x3) for the RTX 50 series or three images (x4) for the RTX 50 series.
It’s the AI that will generate up to three images that will increase the number of FPS, resulting in smoother gameplay and lower memory consumption thanks to the RTX Neural Shaders that can be used to compress textures. This new AI model is 40% faster, uses 30% less VRAM and only needs to run once per rendered image to generate multiple images. The only downside is that these AI-created images will add latency due to the creation process, but NVIDIA will be introducing Reflex 2, which we’ll come back to later in this article.
One thing is certain, NVIDIA is reaping the benefits of having jumped on the AI bandwagon very quickly, and is now leveraging its many years of research against the competition. It’s important to realise that it’s no longer possible to increase raw performance by 25-30% with each generation of graphics cards – it’s the same problem faced by processors, for example. So it was NVIDIA ‘s choice to integrate AI into its cards in order to offer upscaling.
DLSS 4 is only compatible with this new generation of RTX 5000, but the other accompanying technologies will have a positive impact on previous generations. The RTX 5000 and 4000 will also benefit from the improved Frame Generation, with a gain of between 5 and 10% according to NVIDIA, and with lower memory consumption.
As soon as the RTX 5000s arrived, i.e. at the end of January, on the 30th to be precise, 75 games and applications were compatible with DLSS 4 at launch, including Alan Wake 2, Cyberpunk 2077, Indiana Jones and the Great Circle, and Star Wars Outlaws.
The new ‘Transformer’:
DLSS 4 features an updated architecture for DLSS Ray Reconstruction, DLSS Super Resolution and DLAA. Previously, DLSS used convolutional neural networks (CNNs) to generate new pixels, and this has now been replaced by the new Transformer. This should offer greater stability, fewer ghost images, more detail on moving objects and smoother edges.
Slides technologie NVIDIA RTX 5090
This could translate into the possibility of using a Performance mode for the DLSS, which would no longer be visually average, but could approach the Balanced/Quality mode on the previous-generation CNN model. Of course, this will have to be tested and compared in terms of image quality between the RTX 4000 and RTX 5000. It will also be relevant to compare the different DLSS modes in terms of image quality.
The new Transformer will offer improved image quality in Ray Reconstruction, as seen in the image on the left in Alan Wake 2 with the chain link fence. The image on the right shows the improvement in detail between the CNN model and this new generation model.
Reflex 2 technology:
As we said earlier, Multi Frame Generation will allow you to increase the number of FPS, but will add latency because of the creation process. NVIDIA will therefore be offering its version 2 for Reflex. It’s especially in competitive games that these few milliseconds will really make a difference.
NVIDIA Reflex 2 will combine Reflex Low Latency mode with Frame Warp technology and will be compatible with all RTXs. The idea, of course, is to reduce latency, i.e. the time that elapses between the moment you click your mouse button and its appearance on the screen, by displaying a predictive image that is as close as possible to reality. Reflex 2 will be available in the coming weeks.
Override DLSS or the replacement for DLSS :
NVIDIA’s latest application, NVIDIA App, will allow games that have not yet been updated to the latest DLSS models and features to enable support via a DLSS override. The version of the app we will be testing is a press version, and the DLSS replacement options are available in the Graphics > Program Settings screen under Driver Settings.
We will of course be testing Override DLSS during this test to see how easy it is to use. We’ve made an initial assessment of these new technologies, even if we haven’t gone into detail about everything this new RTX 5060 Ti has to offer. It has a 9th generation encoder and a new 6th generation decoder.
[nextpage title=”Technical specifications:”]
A quick trip to GPU-Z to check that the information read is correct. As you can see, this is not yet entirely the case. A new version of GPU-Z will almost certainly be posted after the launch of the RTX 5060 Ti. In the meantime, we can still learn a few things from our copy of the PALIT RTX 5060 Ti Infinity 3 16 GB.
In terms of frequency, GPU-Z has announced a base frequency of 2407 MHz and a boost frequency of 2572 MHz for this PALIT RTX 5060 Ti Infinity 3 16 GB. The card has 16 GB of GDDR7 memory (448 GB/s) on a 128-bit bus at 1750 MHz. This model has the frequencies imposed by NVIDIA, but custom boards can offer factory overclocking depending on their cooling system.
Don’t forget that the GPU frequency may be higher in benchmarks, depending on the quality of your chip and the cooling system used.
In fact, we carried out a test using 3DMark Time Spy to observe the GPU boost frequency. We can see that it reaches the maximum frequency of 2842 MHz at certain times. The memory frequency remains unchanged, which is perfectly normal. GPU-Z reports a power consumption of 181.4 watts, which means that we shouldn’t have much room for overclocking on this model, bearing in mind that the power limit offers no room for improvement, as shown in the screenshot above.
As far as temperatures are concerned, it climbs to 65.1°C and the memory to 66°C. At the time of this first test, it was 21°C in the lab. We’ll have to check the temperatures during our more in-depth tests. The fans are far from running at maximum speed and the card is fairly silent. As a reminder, we’re on a bench and not inside a case. Let’s get on with the first tests!
[nextpage title=”The test configuration: “]
As we said in the introduction, we’ve updated all our graphics using the latest drivers from NVIDIA, AMD and, of course, INTEL. We also took the opportunity to slightly modify our test configuration and add some new games to our protocol. So here we go again, with a new series of tests and graphics on this slightly modified configuration:
  • Motherboard: ROG Maximus Z790 APEX Encore
  • Processor : Intel Alder Lake i9-14900K delid
  • Cooling system: EK-Nucleus AIO CR360 Direct Die D-RGB – 1700
  • Memory: 48 GB Corsair Dominator Titanium 8000 MT/s CL38
  • Graphics card: PALIT RTX 5060 Ti Infinity 3 16 GB, NVIDIA RTX 5070 FE, MSI RTX 5070 Ti Ventus 3X OC, NVIDIA RTX 4070 Ti Super FE, NVIDIA RTX 4070 Ti FE, NVIDIA RTX 4070 Super FE, NVIDIA RTX 4070 FE, AMD RX 7900 GRE and AMD RX 7800 XT
  • SSD: Western Digital Black SN750 2 TB EKWB radiator
  • Power supply: Corsair AX1600i
  • Operating system: Windows 11 64-bit 24H2 (26100.2894)
For this test, we used a fairly high-end configuration based on an i9-14900K delid processor and DDR5 memory. Depending on the definition tested, we used either an MSI Oculux NXG253R or a ROG Strix XG27UCS on loan from ASUS France.
Our test protocol:
All the cards are tested at stock frequencies and without any optimisation. For the various benchmarks, whether for synthetics or games, we will opt for 1080p, 1440p and 2160p resolutions depending on the card’s performance.
Here, with this PALIT RTX 5060 Ti Infinity 3 16 GB model, there’s no doubt about the definition: it will be 1080p and 1440p in rasterisation. We’ll be using DLSS Super Resolution in Performance mode, with Frame Generation or Multi Frame Gernration and ray tracing where available.
As you can see, we’re now running Windows 11 and we’ve activated the ‘ ReSize BAR ‘ in the BIOS, which can be seen in GPU-Z. Now that you know everything about our test configuration, it’s time to get started!
[nextpage title=”3DMark benchmarks: “]
Our first series of tests will be dedicated to synthetic benchmarks. These are very often used for overclocking competitions , but are also very interesting for comparing different GPUs. So we’ll be focusing on benchmarks from the 3DMark series. For this new version of our graphics, and for the 3DMark tests, we have also isolated the GPU score. So you’ll find, where stipulated in the benchmark, the overall score and the GPU score.
3DMark Fire Strike and Fire Strike Ultra :
Let’s start with 3DMark Fire Strike, which is one of the most widely used benchmarks today. It consists of two graphics tests, a CPU test and a fourth test that combines GPU and CPU. Don’t forget to disable the demo, which makes no difference to the final score and (unnecessarily) prolongs the benchmark. The version used for these tests is, of course, the latest.
We begin our tests with the two Fire Strike and Fire Strike Ultra benchmarks. One thing we’re unfortunately going to miss in today’s graphics is the presence of a 16GB version of the RTX 4060 Ti. We’ll have to make do with the ‘8 GB’ version. The least we can say is that things are off to a good start, with a clear difference in performance compared to the previous generation and results close to those of the RTX 4070 FE.
3DMark Time Spy and Time Spy Extreme:
The second test is 3DMark Time Spy. Although this one is run in 1440p, its main feature is that it uses DirectX 12. It consists of two graphics tests and a CPU test. As with Fire Strike, don’t forget to disable the demo. These first two benchmarks are provided by UL Benchmark.
We continue with Time Spy, where the results are slightly behind the RTX 4070 FE, but still well ahead of the previous generation. Time Spy gives an initial idea of in-game performance, so we should have our PALIT RTX 5060 Ti Infinity 3 16 GB in a good position against the competition. However, and we’ll come back to this in our article, the difference with the RTX 5070 FE is very significant!
3DMark Speed Way :
The latest benchmark from Ulbenchmark, and it’s great to be able to say that we’re going to have a good go at this Speed Way. It uses DirectX 12 and is set to 1440p by default. We haven’t changed anything, so we’re using the original benchmark.
In Speed Way, our PALIT RTX 5060 Ti Infinity 3 16 GB obtained a score of 4144 points, which represents a 26% gain on the RTX 4060 Ti 8 GB and a 9% drop on the RTX 4070 FE.
3DMark Port Royal :
This is a benchmark that we left out last year, but which you were keen to see again in our tests. It’s still widely used, particularly in the overclocking community . So we’ve decided to add it to our tests.
In Port Royal, our PALIT RTX 5060 Ti Infinity 3 16 GB passes the 10K mark with a score of 10248 points.
3DMark Steel Nomad :
The latest benchmark in the 3DMark suite, Steel Nomad will replace Time Spy as the most recent benchmark in the 3DMark suite. However, the good news is that it will be free for users who already have a key. The programme includes a test bench based on Microsoft’s DirectX12 API. However, there will be no ray tracing, but the scene will use an ‘extreme’ level of geometry and rasterised light.
Finally, the last benchmark in the 3DMark series, Steel Nomad, which has just arrived, gave our PALIT RTX 5060 Ti Infinity 3 16 GB an excellent performance, with a score of 3,588 points, 23% better than the RTX 4070 Ti 8 GB.
[nextpage title=”UL Procyon AI Image / Text Generation:”]
UL Procyon AI Image Generation:
UL Benchmark not only offers its 3DMark benchmark suite but also, UL Procyon, to meet the demand for Artificial Intelligence evaluation. This benchmark was chosen for its ease of implementation. The benchmark will generate 4 x 4 images and provide us with a score as well as a result in the form of the time, in seconds, required to generate an image. The software supports several AI inference engines depending on the GPU used.
We will therefore use the benchmark in Stable Diffusion 1.5 (FP16) mode. It is intended for mid-range GPUs. The test will create 16 images at a resolution of 512 x 512 in batches of 4. There is a test called Stable Diffusion XL (FP16), where 16 images will be created, at 1024 x 1024, in batches of 1.
As the program has just undergone a major update, we had to run all our cards again, including the RTX 5000 series. The timing was too tight to have time to retest them all, so it will be updated asap.
UL Procyon AI Text Generation :
The latest benchmark added to this test suite, AI Text Generation. The Procyon AI Text Generation Benchmark provides a more compact and easier way to repeatedly and consistently test AI performance with multiple LLM AI models. UL says it has worked closely with many AI software and hardware leaders to ensure that the benchmark tests take full advantage of the local AI accelerator of the systems used.
Performance has improved on the previous generation, since in this series of tests our PALIT RTX 5060 Ti Infinity 3 16 GB did better than the RTX 4070 FE and also the RTX 4070 Ti version!
V-Ray 6:
A new benchmark to add to those we use to test our graphics cards. The V-Ray 6 benchmark is produced by the Chaos company to enable users to quickly assess the rendering speeds of both your processor and your graphics card, which is why we’re adding it today. The great thing is that it’s free and can be downloaded directly by following this link. You can then compare your score directly with those below, or directly online on the Chaos page.
This benchmark has just been integrated into our tests, and we still have to run all our 1080p definition cards again. The difference here with the RTX 4070 FE is 36 points.
[nextpage title=”Gaming rasterisation performance 1080p – 1440p: “]
Let’s get on with the gaming tests. We’ve used all the graphics cards we thought would be interesting to compare with this PALIT RTX 5060 Ti Infinity 3 16 GB in 1080p and 1440p definition. In the coming weeks, we’ll be bringing you a new type of article, retesting graphics cards from previous generations to find out what they’re still worth in 2025. Our games panel currently consists of 13 titles, and will be growing over the coming weeks.
We have chosen to use the benchmarks built into these games.
Why have we done this? Quite simply to allow you to do the same if you also have a copy of one of these games. It’s a thought-provoking idea that will allow you to compare your results with ours. The number and titles selected have changed slightly, and will increase again over the coming weeks as we get our hands on new games.
What is rasterisation?
Before we start, a quick word about ‘rasterisation’, which is currently the subject of much discussion. Rasterisation is the evaluation of the performance of our graphics cards without using upscaling technologies . We choose a graphics quality, often the highest, and test it. The advantage of these tests is that we can quantify the gain in architecture between different generations.
Borderlands 3 :
Let’s get on with the gaming part, starting with Borderlands 3. As we suggested in the introduction, 1080p definition should be a formality for our PALIT RTX 5060 Ti Infinity 3 16 GB. Nevertheless, we decided to test it in 1080p so as to be able to judge the gains over the previous generation.
In 1440p, and this is logical, our PALIT RTX 5060 Ti Infinity 3 16 GB will often occupy last place, but the idea will be to see if it can hang on to an average of 60 FPS in our various games. And it’s off to a pretty good start with Borderlands 3, as we get an average of 97.2 FPS in 1440p.
Cyberpunk 2077:
The same applies to Cyberpunk 2077, where our PALIT RTX 5060 Ti Infinity 3 16 GB crushes the competition in 1080p and achieves an average of 79.8 FPS in 1440p, beating out the RTX 4070 FE. We didn’t choose to switch the RTX 4060 Ti 8 GB to 1440p at the time, because when you see the difference in 1080p with the RTX 5060 Ti 16 GB, it would have suffered, especially with our graphics settings pushed to maximum.
COD Modern Warfare III:
We’re not really changing the shape of our graphics, but we know that COD MWIII is more to the advantage of AMD cards. Here, our PALIT RTX 5060 Ti Infinity 3 16 GB maintains a very interesting FPS average at 1440p.
Forspoken:
Forspoken is a fairly demanding game and PALIT RTX 5060 Ti Infinity 3 16 GB achieves an average of 56 FPS in 1440p, the first time the 60 FPS mark has not been reached.
Horizon Zeron Dawn Remastered:
One of the new games we’ve added to our comparison, and once again our PALIT RTX 5060 Ti Infinity 3 16 GB achieves a very comfortable FPS average.
Shadow Of The Tomb Raider:
Shadow Of The Tomb Raider easily passes the 150 FPS mark at 1440p.
Black Myth: Wukong Benchmark Tool :
This new game also seems very greedy, as our average drops to 43 FPS in 1440p and struggles to reach 60 FPS in 1080p. Graphics adjustments will be necessary for this game. Note that we made a mistake in our graphics and that the graphic definition is not ‘ultra’, but ‘cinema’ in 1440p.
Far Cry 6:
Performance remains excellent for our PALIT RTX 5060 Ti Infinity 3 16 GB.
Assassin’s Creed Mirage :
Well, you’re beginning to read between the lines for our two definitions: the PALIT RTX 5060 Ti Infinity 3 16 GB. crushes everything in 1080p and maintains a very satisfactory FPS average in 1440p.
Red Dead Redemption II:
With Red Dead Redemption II, there are no changes, and the performance is just as good.
F1 2024 :
Our sample of the day averages 79 FPS in 1440p. We haven’t yet had a chance to test our next three games in 1080p, but this will be done in the coming weeks with the cards we still have available.
Monster Hunter Wilds:
A new benchmark also makes its debut, with an average of 55.5 FPS at 1440p.
Alan Wake 2:
The latest game, Alan Wake 2 won’t disturb our feelings, with our PALIT RTX 5060 Ti Infinity 3 16 GB just managing to reach 60 FPS.
Average for games in 1080p and 1440p rasterisation:
Let’s start with the 1080p performance, which we won’t go into here, as our PALIT RTX 5060 Ti Infinity 3 16 GB is totally dominant. We have seen almost 30% more performance than the RTX 4060 Ti, albeit in the 8 GB version. The differences would have been slightly smaller with the 16 GB version.
In 1440p, compared with the new benchmark for this definition, the RTX 5070 FE, our PALIT RTX 5060 Ti Infinity 3 16 GB. is almost 24% behind. It’s easy to imagine that this space is ready for a future RTX 5060 Ti SUPER? One thing is certain, this RTX 5060 Ti model will be able to take full advantage of 1440p definition. We’ll see how we can reduce this gap even further with models that have an interesting overclocking margin.
[nextpage title=”1440p gaming upscaling performance:”]
In this section, we’re going to test our graphics cards by activating ray tracing, if available, and upscaling depending on the graphics card used. As a reminder, there are currently three upscaling technologies . NVIDIA has DLSS, which can only be activated with NVIDIA cards. Depending on the generation of your GPU, you may or may not be able to take advantage of all the technologies offered by the Greens. At AMD, it’s FSR, which is also evolving and also benefits from Frame Generation for certain games.
Intel’s in-house upscaling is called XeSS, and with the arrival of this new generation of graphics cards, Intel has taken the opportunity to announce the arrival of XeSS 2, which will introduce two new features to compete with NVIDIA and AMD, who are already ahead in this field. Intel will be offering Xe Frame Generation (XeSS-FG) and XeSS Low Latency (XeLL).
Finally, it is important to point out that some games do not have ray tracing, but only an upscaling solution. We’ll make this clear in the games below. For 1440p definition, upscaling, whether in DLSS or FSR, will always be in Performance mode.
Cyberpunk 2077:
Here we go again, with Cyberpunk 2077 as our first game. Our NVIDIA cards are in front. Please note that, for the purposes of comparison, only Frame Generation x2 is used with the RTX 5000. Multi Frame Generation will be discussed on the next page. In 1440p, our PALIT RTX 5060 Ti Infinity 3 16 GB suffers with an average of 34.3 FPS when ray tracing is active, but improves to an average of 128.6 FPS with Frame Generation (x2). Mind you, if we had activated MFG, our card would have taken the lead at x3 and x4. We’ll tell you all about it on the next page, with a series of DLSS 4-compatible games.
No worries in Call Of Duty Modern Warfare III, where upscaling still allows you to gain FPS, and even many, many FPS. We’ll be coming back to the quality of the different upscaling options once the new GPU launches have calmed down.
Forspoken:
The same applies to our PALIT RTX 5060 Ti Infinity 3 16 GB. when rasterised, it drops below 60 FPS and upscaling boosts performance.
Horizon Zeron Dawn Remastered :
The same is true of Horizon Zeron Dawn Remastered, where Frame Generation delivers an average of 172 FPS.
Here we go again with Black Myth: Wukong, a very demanding game that benefits from ray tracing. And it’s in this very type of case that upscaling comes in handy, as the PALIT RTX 5060 Ti Infinity 3 16 GB barely manages 1440p.
Far Cry 6:
No DLSS here, we’re using AMD’s upscaling, which explains the very low gain between DXR and upscaling mode.
The same applies to Assassin’s Creed Mirage: our PALIT RTX 5060 Ti Infinity 3 16 GB has no problems whatsoever.
F1 24 :
The penultimate game on our test panel, DLSS Performance combined with Frame Generation enabled our model of the day to achieve an average of 164 FPS at 1440p.
Monster Hunter Wilds :
Ninth and final game, and same observation, with our PALIT RTX 5060 Ti Infinity 3 16 GB, which benefits from upscaling combined with Frame Generation.
What do you think of upscaling with the PALIT RTX 5060 Ti Infinity 3 16 GB?
Our PALIT RTX 5060 Ti Infinity 3 16 GB. already does pretty well with upscaling, whether in 1440p or 2160p, with the exception of the game Black Myth: Wukong. Upscaling isn’t always necessary in 1440p, but it does provide a significant performance boost.
As we’ve already implied on several occasions in our previous tests, we recommend an average of fairly close to 60 FPS before using Frame Generation in order to maintain an optimal gaming experience and avoid the latency that could result. We received a 240Hz QD-LED screen, which will allow us to highlight this point in a future article.
[nextpage title=”Games that support DLSS 4:”]
A series of games are already DLSS 4 compatible, on the day the RTX 5080/5090 is launched. We’ve been able to get hold of them in order to start a series of tests and highlight the performance achieved thanks to DLSS 4. We’ll be coming back to the qualitative side of the rendering in detail in the coming weeks. Of course, the upscaling principle here will be to support our PALIT RTX 5060 Ti Infinity 3 16 GB face at 1440p performance with the graphics options at maximum, as well as ray tracing or path tracing if available.
To measure our FPS, we had access to a beta version of CapFrameX v1.7.5. This measurement tool is certainly one of the best and most intuitive when the game doesn’t have an integrated benchmark. If you’re interested, we can go into more detail on how to use it in a separate article. We wanted to see how our PALIT RTX 5060 Ti Infinity 3 16 GB would perform with the Multi Frame Generation available for the RTX 5000.
Cyberpunk 2077:
First of all, with ray tracing in Overdrive mode , all the cards suffer. In 1440p, our PALIT RTX 5060 Ti Infinity 3 16 GB achieves an average of 18.3 FPS. This average increases with the use of MFG x2, x3 or x4. This is the typical case where we advise you to lower the graphics options to get a comfortable ray tracing average before activating the MFG.
Hogwarts Legacy: The Hogwarts Legacy
The same is true of Hogwarts Legacy, where in 1440p rasterisation we managed to achieve an average of 48 FPS, which was already close to 60 FPS before the MFG was used.
Alan Wake 2:
The same applies to Alan Wake 2: our cards suffer when the graphics options are set to maximum. You’ll have to be less greedy before resorting to the MFG.
Star Wars Outlaws :
The feeling of going from 26 FPS to 178 FPS in 1440p for our PALIT RTX 5060 Ti Infinity 3 16 GB remains a sensation to be tested in-game. The number of native FPS and those generated seem to us to be really unbalanced. As you can see, we’ll have to look at the visual quality of the various upscaling options and how it feels in-game with Frame Generation or Multi Frame Generation activated.
[nextpage title=”The final word:”]
So, what do we think of this PALIT RTX 5060 Ti Infinity 3 16 GB?
In the end, this model, which we weren’t really expecting, performs very well, with a very interesting gain in rasterisation. For us, the RTX 4060 Ti 8GB/16GB was the best choice for 1080p definition, but this new RTX 5060 Ti raises the bar even higher, allowing it to play in the 1440p card league. Admittedly, you may have to make some graphical concessions on some of the more demanding games, but overall, it’s no problem at all. If you want to use Multi Frame Generation, don’t forget to maintain a sufficient average native FPS before activating it, otherwise your gaming experience may be altered.
With this 16GB RTX 5060 Ti Infinity 3 model, PALIT is offering us a high-performance card that’s ready to take on 1440p definition. You might even say that, in the end, it’s too powerful to be content with 1080p. It ‘should’ be available at the MSRP price, i.e. 449 euros, which for us is a rather attractive price, given that the RTX 4060 Ti 16GB was offered at 549 euros when it was launched! If we look at NVIDIA’s higher-end range, we find the RTX 5070 with an MSRP of 649 euros, also offering higher performance, but the ratio is more in favour of this RTX 5060 Ti.
In terms of design, it has an 8-pin power connector, which could well appeal to those who don’t want to change their power supply and who own at least one 600-watt model. The cooling system is effective, but it’s worth remembering that the entire casing is made entirely of plastic, although once you’re inside your case, this will be of less importance.
Should you sell your RTX 4060 Ti 16 GB?
Well, that’s going to change slightly. If you have a 1080p screen, certainly not, your RTX 4060 Ti 16 GB still does the job perfectly! On the other hand, if your display is compatible with 1440p or if you’re planning to buy one in the next few weeks, this RTX 5060 Ti 16 GB could prove interesting. It has 16 GB of GDDR7, can (logically) be found in MSRP at 449 euros and benefits from Multi Frame Generation, which can be an asset in 1440p to complement the card’s performance.
We didn’t have time to look at overclocking because of the tight schedule, with two of our three cards arriving only on Friday. We’re going to cover this subject quickly, though, because if in the end the three RTX 5060 Ti cards tested today differ by between 1% and 3% in terms of performance, overclocking could change all that. So stay tuned over the coming days to discover the potential of our three graphics cards. Now, we don’t expect to be able to make huge gains with this Palit model, as the power limit cannot be increased.
A final word about the “8 GB” versions, which we haven’t tested, but which seem to us to be less interesting than the “16 GB” versions, especially when it comes to taking advantage of the 1440p definition. Thanks to NVIDIA for making this sample of the PALIT RTX 5060 Ti Infinity 3 16 GB available.
CornerJack
CornerJack
Le belge de l'équipe, à l'affut des nouveautés du monde hardware et plus particulièrement intéressé par ce qui touche à l'overclocking ! Propriétaire d'overclex.net, j'ai rejoint l'équipe d'overclocking.com en 2019 !
