Head over to MSI, whose entire RTX 5060 Ti 16GB range has just been leaked. Indeed, @I_Leak_VN has shared a screenshot revealing a total of nine new cards. However, this series does not include a Suprim model, and the top-of-the-range version will be a Vanguard variant!
RTX 5060 Ti 16GB: no Suprim series from MSI!
MSI is planning to launch a total of nine cards based on the 5060 Ti with 16 GB of VRAM. The top-of-the-range card would be a Vanguard model, a sort of Gaming Trio on steroids! But that would be the end of it, as MSI doesn’t seem to be planning a Suprim model. On the other hand, this is also a prestigious series, reserved for the biggest GPUs. For example, there is no Suprim in RTX 5070 Ti or RTX 5070 either.
Next, MSI will be releasing two Gaming Trio models, including a white version. Here, both cards are overclocked as standard. Then there’s a single Inspire model, which is said to feature two fans, as the 2X designation suggests. It’s also worth noting that a dual-fan Inspire would be a first for the series.
We continue with a whole host of Ventus cards, as the brand is planning four variations… There are models with two or three fans foroverclocking, a white version, and a more basic model.
Finally, we end with the entry-level range represented by the Shadow series, available here in a two-fan version… In addition to factory overclocking. Of course, this is just a glimpse of what MSI will be offering for its series, but we can expect an even more comprehensive range with the non-OC versions of the cards, for example.
In short, with NVIDIA, it’s not unusual to see cards available in 50 different models, which is not the case with AMD!
