Today, we’re testing the Legend 860, an SSD from ADATA. The Taiwanese brand needs no introduction—it has been active in the memory and storage industry for over 20 years and also markets its gaming products under the XPG brand. The Legend 860, meanwhile, is part of its consumer lineup.
On paper, this is a PCIe Gen 4 M.2 SSD, with advertised performance of up to 6,000 MB/s read and 4,000 MB/s write in its 1 TB version. It has no DRAM cache, but it comes with a heat sink included in the box and a 5-year warranty. This makes it a great fit for both gaming PCs and PS5s running low on storage, especially since the release of GTA 6 and its 212 GB requirement. In fact, this is the model we recommended in our article on choosing an SSD for the PS5.
But how does this SSD really stack up in a storage market that’s not exactly thriving, with memory and storage prices skyrocketing? We’ll give you our answer in this review!
Thanks to XPG for providing this unit!
The Legend 860:
Unboxing:
The Legend 860 comes in relatively simple packaging. On the front, you’ll find an overview of the product and its key features, such as its capacity, model, and PCIe Gen 4 interface. Additional information is provided on the back of the box.
Once the box is opened, we find a cardboard insert containing and protecting the SSD. It is very securely held in place and won’t shift during shipping.
Inside this cardboard sleeve, you’ll find the SSD and its heatsink. Both are stored in a plastic bag. The heatsink is not attached to the SSD by default, allowing you to install the SSD under a motherboard heatsink without having to remove the one provided by Adata.
The SSD in detail:
The Adata Legend 860 is one of the brand’s mid-range SSDs. Despite this positioning, its build quality and performance are still quite solid and impressive in a modern PC. The model we’re reviewing today is available in three capacities: 500 GB, 1 TB, and 2 TB. These versions also offer different performance levels, with maximum sequential read and write speeds of 5,000 MB/s and 3,000 MB/s for the 500 GB model. These figures rise to 6,000 MB/s and 4,000 MB/s for the 1 TB version, and finally to 6,000 MB/s and 5,000 MB/s for the largest capacity model. In our case, for this test, we have the 1 TB model, which is the most widely available.
On the hardware side, the Legend 860 is based on a Phison PS5033-E33-75 controller. This chip handles the SSD’s read and write operations, distributing data across the storage chips and ensuring they wear out evenly.
The chip powering our SSD is a model about which little information is available. However, it is believed to be intended for OEMs—that is, manufacturers like Adata that integrate it directly into their products. Without a public datasheet, it’s difficult to say more about this E33. However, it appears to be similar to Phison’s E27T, a PCIe Gen 4 x4 controller manufactured by TSMC using a 12-nm process. This controller is reportedly capable of utilizing 4 channels, supports both TLC and QLC, and does not require DRAM.
Furthermore, during our research, we noticed that our unit appears to be a newer revision of the Legend 860. Its PCB is completely different from those of the models seen in other reviews, which are equipped with a Silicon Motion SM2268XT2. Furthermore, ADATA does not specify the controller in its technical specifications, so components may vary from batch to batch. The results of this test therefore apply to the Phison version of the Legend 860.
For storage, ADATA has opted here for two 512 GB QLC NAND chips, for a total of 1,024 GB. Of this total, 1,000 GB are accessible to the user. The remainder is reserved by the controller to manage cell wear and replace worn-out cells. This simple layout leaves a good portion of the PCB free.
These NAND chips are known as QLC—or, to be precise, Quad-Level Cell—meaning that each cell stores 4 bits, compared to 3 bits for TLC. This allows more data to be stored on the same surface area, which helps reduce costs. On the downside, write speeds are slower and endurance is lower.
To compensate, the SSD uses a dynamic SLC cache. A portion of the NAND temporarily operates at 1 bit per cell, allowing for much faster writes. As long as this cache isn’t full, you’ll enjoy maximum transfer speeds. Once it’s full, the write speed drops. This is therefore the key factor to watch for during large data transfers, and we’ll be examining it closely in our benchmarks!
Regarding endurance, ADATA specifies a TBW (total bytes written—the amount of data that can be written to the SSD) of 320 TB for the 1 TB version. This equates to approximately 175 GB per day over the 5-year warranty period—a capacity that should be more than sufficient for typical use!
As is often the case with this type of SSD, there’s no DRAM chip. DRAM is typically used to store the mapping table, which indicates where each piece of data is located on the NAND. Here, the SSD relies on the HMB (Host Memory Buffer). In other words, it borrows a small portion of the computer’s RAM to keep this table readily available. It’s a cost-effective solution that doesn’t really pose any problems when loading games.
Feature Summary:
| Feature | Specification |
| Available capacities | 500 GB / 1 TB / 2 TB |
| Form Factor | M.2 2280 |
| Interface | PCIe 4.0 x4 |
| Protocol | NVMe |
| NAND Memory | 3D NAND |
| Max. sequential read speed | 5,000 MB/s (500 GB) / 6,000 MB/s (1 TB and 2 TB) |
| Max. sequential write | 3,000 MB/s (500 GB) / 4,000 MB/s (1 TB) / 5,000 MB/s (2 TB) |
| Cache | SLC / HMB |
| Heat sink | Yes |
| Endurance (TBW) | 160 / 320 / 640 TB (depending on capacity) |
| MTBF | 2,000,000 hours |
| Warranty | 5 years |
Test protocol:
Our protocol:
To evaluate this SSD, we’ll use an AMD configuration. Specifically, we’ll use a Sapphire B850M Nitro+ motherboard paired with a Ryzen 9 7950X3D processor. This is a high-performance platform that takes advantage of AMD’s renowned 3D cache.
As for the performance figures we recorded for this SSD, they can vary by about 100 MB/s from one configuration to another. This depends mainly on your processor, your BIOS, and the SSD’s temperature…
To provide results that most closely match what you’ll experience once the SSD is installed in your PC, we ran all tests with the SSD mounted on a motherboard heatsink. If you don’t have one, we strongly recommend purchasing one separately. Even with low temperatures for a Gen 4 SSD, thermal throttling can occur during use.
Finally, to ensure the most accurate and reliable results possible, the tests were repeated several times—at least twice, and up to three times in some cases.
Test configuration:
- Motherboard: Sapphire B850M Nitro+
- Processor: AMD Ryzen 9 7950X3D
- Memory: Corsair Vengeance RGB 6000 MT/s CL30 (2 x 16 GB)
- Graphics card: Asus TUF 1660 SUPER
- Cooling system: be quiet! Pure Loop 2 240 mm
- SSD: Adata Legend 860 1TB
- Power Supply: NZXT C1500 Platinum
- Operating system: Windows 11 (25H2)
Benchmarks used:
- 3DMark Storage Benchmark
- Crystal Disk Mark
- ATTO Disk Benchmark
- AS SSD Benchmark
- PCMark 10
- Anvil Benchmark
Performance:
CrystalDiskMark:
The first test we’ll run on this SSD is the standard CrystalDiskMark. It will let us see the sequential and random read and write speeds this SSD is capable of. We immediately notice that the data provided by the manufacturer matches what we found in our first test.
The results we obtained were quite surprising. Adata claims read and write speeds of up to 6,000 MB/s and 5,000 MB/s, respectively. Our measurements show that these speeds are significantly exceeded, with over 7,400 MB/s for read speeds and 6,100 MB/s for write speeds. This places this model among the top performers in the Gen 4 SSD category.
AS SSD:
Next up is AS SSD, where we’ll again examine sequential read and write speeds. We’ll be most interested in the 4K, 4K 64-thread, and access time measurements. This benchmark allows us to assess performance under heavy workloads, such as video processing.
ATTO Disk:
We’ll now measure the SSD’s read and write speeds based on file size. The file sizes tested range from 512 B to 64 MB.
We can see here that performance plateaus at file sizes of 64 KB and above. Nevertheless, performance remains very good.
Anvil Benchmark:
Here, we’ll compare latency once again using different tasks. This will allow us to measure the SSD’s access and response times for specific tasks. This test simulates real-world, everyday usage scenarios.
The Legend 860 achieves scores consistent with what we measured previously. Latency times are generally very good.
3DMark Storage Benchmark:
We’ll now move on to the gaming benchmark. This test will allow us to determine the bandwidth and average access time for various game titles. It will measure load times for games like Battlefield 5 and Call of Duty: Black Ops 4.
The results show that the SSD is perfectly capable of handling gaming. Its performance is very close to that of a model equipped with a Gen 5 interface. This confirms once again that, for gaming today, a good Gen 4 SSD is perfectly adequate.
PCMark 10:
We’ll wrap up our tests with three PCMark 10 benchmarks: “Quick System Drive Benchmark,” “Data Drive Benchmark,” and “Full System Drive Benchmark.” These tests simulate “normal” everyday use of the SSD. We then obtain the bandwidth and average access time.
For office tasks, the Adata Legend 860 is also an excellent storage device. It offers high transfer speeds and low response times.
Heat:
Temperatures of the Adata Legend 860:
When we test an SSD equipped with Gen 5 technology, we often emphasize the importance of keeping heat levels in check. Here, with the Legend 860 and its PCIe Gen 4 interface, this point isn’t as critical. Nevertheless, it remains an important detail that can influence its performance. We will therefore measure whether heat is kept under control.
To simulate intensive use, we will run the CrystalDiskMark test more than five times in a row. Then, we will record the maximum temperature reached by the SSD.
In the end, the temperatures turned out to be quite low. They did not exceed 49 degrees during more than five consecutive CrystalDiskMark tests. We even continued the tests a little longer, resulting in a maximum temperature of 50 degrees. This relatively low temperature can be attributed to the large heat sink installed on our Sapphire B850M Nitro+ motherboard. However, expect higher temperatures if your motherboard is equipped with a smaller heat sink—though they won’t reach excessive levels.
Compared to Other SSDs:
To compare the performance of this Adata SSD with that of SSDs we’ve previously tested, we’ve provided several tables below. Of course, these tables include SSDs with the Gen 5 interface. It’s therefore normal for the Legend 860 to rank toward the bottom of the table.
In this first table, we can easily compare the sequential read and write speeds recorded using CrystalDiskMark during our tests. Here we can see that the Legend is a Gen 4 SSD with fast read and write speeds.
The second table is based on the 3DMark Storage test, which allows us to compare the SSD’s performance in games. We can see that the SSD trails behind Gen 5 SSDs (which is hardly surprising). But overall, it delivers very good performance compared to its Gen 4 competitors.
Finally, the third and last table shows the data from our PCMark 10 tests, which illustrate the SSD’s performance in professional and everyday use. Once again, the Legend 860 holds its own against the competition.
Conclusion:
Performance:
Let’s start with the SSD itself. On paper, a QLC model without DRAM isn’t exactly a dream come true. But once on our test bench, it’s a whole different story! With 7,100 MB/s read and 6,000 MB/s write speeds in CrystalDiskMark, it outperforms the 6,000 and 4,000 MB/s advertised by ADATA for this 1 TB version. And let’s face it, it’s pretty rare to see an SSD exceed its spec sheet by such a wide margin.
Temperature:
Now let’s move on to temperatures. On that front, nothing to report! The Legend 860’s temperatures remained perfectly under control throughout our tests. So there’s really no cause for concern during typical use, whether for gaming or for storing your files on a daily basis. Furthermore, the recorded temperatures confirm that installing it in a laptop or a PS5 will be entirely possible.
Our Final Thoughts:
All in all, the Legend 860 pleasantly surprised us, particularly thanks to its performance exceeding what was advertised. That leaves the thorny issue: the price. With the skyrocketing costs of memory and storage we’re all experiencing, this type of SSD has become very expensive, and you’ll need to budget around €170 for this model. It’s a steep price, let’s be honest. But compared to other models on the market, the price is generally in line with the competition. And if you’re going to pay top dollar, you might as well do it for an SSD that delivers more than what’s written on the box.
Review: Adata Legend 860 1 TB
Les +
- Performance
- Heating
- 5-Year Warranty
Les -
- Limited availability
- The price (given the current crisis)
High-performing, with well-controlled temperatures, and available at a reasonable price for today's market, the Adata Legend 860 is an SSD we can recommend without hesitation—whether for a PC or a PS5!
