Overclocking.com video
Technical specifications
The Light Mount and Dark Mount keyboards share a common base: the same silent switches, the same build quality, and the same customisation software.
The Light Mount is a keyboard with an integrated numeric keypad. A 100% classic.
The Dark Mount, on the other hand, is in the basic TKL format, but becomes a 100% keyboard thanks to its removable numeric keypad, which can be fixed to the left or right as required.
| Specifications | Light Mount | Dark Mount |
| Recommended retail price (MSRP) | 169,90 € | 259,90 € |
| Modularity | No | Yes – removable keypad & multimedia module |
| Programmable keys with display | No | 8 keys with display (GIF/JPG/PNG) |
| Switch type | Be quiet! mufflers (linear orange or tactile black), lubricated | Same as |
| Actuating force | 45g (linear), 55g (tactile) | 45g (linear), 55g (tactile) |
| Sound damping | 3 layers of foam | 3 layers silicone foam space bar |
| Keycaps | PBT double layer | PBT double injection |
| ARGB backlighting | Diffuser on each switch top and side strips | Illumination key by key diffuser edges |
| Layout | Full size, ANSI & ISO | Full size, ANSI & ISO |
| Stabilisers | Cherry plate-mounted, lubricated | Cherry screwed-in, lubricated |
| Top plate | Brushed aluminium | Brushed aluminium |
| Wrist rest | Magnetic, modular | Magnetic, two-part |
| Adjustable feet | Retractable, 3 positions | Magnetic, adjustable to 3 angles (3°, 6°, 9°) |
| On-board memory | Yes | Yes |
| Connections | USB 3.2 Gen 2 Type-C | USB 3.2 Gen 2 Type-C |
| Polling rate | 1000 Hz | Adjustable 125 / 250 / 500 / 1000 Hz |
| Dimensions (mm) | 132 x 461 x 44 mm | 174 x 456 x 52 mm |
| Weight | 0.91 kg | 1.38 kg |
| Software | IO Center (Windows Web) | IO Center (Windows Web) |
