The test configuration:
Lately, we have once again updated all our graphics using the latest drivers from NVIDIA, AMD and of course Intel. We also took the opportunity to slightly modify our test configuration. So here we go again for a new series of tests and therefore of graphics on this slightly modified configuration:
- Motherboard : ROG Maximus Z690 APEX
- Processor : Intel Alder Lake i9-12900K
- Memory : 32 GB Corsair Vengeance 5600 CL38 DDR5
- Graphics Card: AMD Radeon RX 7900 XT and RX 7900 XTX
- Cooling system : ROG Ryujin II 360
- SSD : Western Digital Black SN750 2 TB + EKWB radiator
- Power supply: Corsair AX1600i + 12VHPWR 600W adapter
- Operating system : Windows 11 64 bits
For this test, we used a high-end configuration using an i9-12900K processor and DDR5. The use of a 144 Hz 4K display is also a prerequisite. For our tests we use a copy of the ROG PG27UQ.
The drivers used are NVIDIA 517.48 and AMD 22.9.2. For the two AMD cards, we used the press drivers in version 22.40.00.57
Our test protocol:
All cards are tested at stock frequencies and without any optimization. For the various benchmarks, whether synthetic or gaming, we will opt for 1080p, 1440p and 2160p resolutions depending on the card’s performance. Here, with this ultra high-end model, we will only use the 2160p definition since we will be comparing it mainly to NVIDIA’s RTX 4080 FE.
As you have seen, we have switched to Windows 11 and we have enabled in the BIOS, the ” ReSize BAR ” visible in GPU-Z. Now that you know everything about our test configuration, it’s time to start!
