Azza announces a new version of its pyramid case. This new version replaces the tempered glass panels with metal mesh panels. You will have understood, the interest is to improve the air flow inside this model !
Pyramid 804M Mesh : it must breathe better !
With this new version, we still find a case measuring 490 mm on the side for a height of 585 mm. The weight is still consistent with 12.9 kg on the scale.
Inside, the motherboard tray is quite spacious and offers a support with E-ATX models at the maximum. For the graphics card, we only find three horizontal expansion slots. Nevertheless, the clearance is sufficient with 330 mm length. On the other hand, the height for a CPU cooling unit is disappointing with only 95 mm. Nevertheless, we can make up for it with watercooling since this case can accommodate a 360 mm radiator.
For ventilation, we have a total of six slots in 120 mm. One of them is positioned at the top, while the other four take place at the bottom of the case.
Finally, for the storage part, we have up to two 2.5″ slots against one in 3.5″.
The pricing is, to say the least, elitist since the case is priced at $419.99. Clearly, this is not cheap for such an imposing model that has so many constraints. What you pay for is the original design.
