ProCube Mini: a cubic case for ITX motherboards!
New case from Chieftec who unveils its ProCube Mini. It is about a new reference in cube format. In short, a new reference that comes to add to the catalog of the brand!
ProCube Mini : new ITX case for Chieftec !
Chieftec ProCube MiniOn the program, we find a small size case for Chieftech. The brand announces a model measuring 260 (W) x 356 (D) x 195 (H) mm. As for the weight, it won’t weigh much with its 4,4 kg on the scale!
Inside, we will be limited to a motherboard in mini-ITX format and a maximum of 145 mm of cooling. However, the graphics part benefits from 230 mm to 320 mm depending on the depth of the power supply… Which can be in ATX format. Of course, it is better to choose a 14 cm deep model rather than a 20 cm block.
Via a board system, it will be possible to install up to three 3.5″ hard drives and two 2.5″ SSDs. Also, this case offers something rare these days: a 5.25″ bay for a slim optical drive.
Finally, the ventilation will be asthmatic. Indeed, the only available slot is located at the back of the case and is compatible with fans or a watercooling radiator in 120 mm!
Currently, we do not know the selling price. For the availability, Chieftec announces July 2022… We will surely have the price then.
Here is the technical data sheet of Chieftec!
