NZXT announces its H6 Flow, a mini H9!
After launching the H9, the NZXT brand now introduces the H6, a case in the same spirit, but much more compact. This Flow version features perforated panels and three fans as standard for maximum airflow!
H6 Flow: compartmentalized, panoramic and airflow-oriented!
NZXT H6 Flow noirWith this new case, we find a sober model equipped with two glass panels, one on the side, the second on the front. Naturally, with NZXT, the visual aspect is uncluttered.
The case is available in two versions: a Flow model and a Flow RGB version. The main difference lies in the ventilation, with aRGB mills in one case and not in the other.
Otherwise, the same technical specifications apply, with a case measuring 287 (W) x 415 (D) x 435 (H) mm. Weight is 9.4 kg, while the chassis is made of steel.
An ATX-format motherboard can be fitted internally. The CPU cooler is 163 mm high. Finally, the graphics card can measure up to 365 mm in length.
NZXT H6
Basic ventilation consists of three 120 mm fans mounted on the oblique panel. These will water the graphics card directly. Otherwise, there are three other 120 mm slots at the top, two at the bottom and one at the rear.
For watercooling, compatibility with 360 mm radiators is ensured at the top. At the bottom, you’ll have to make do with a smaller model: 240 mm.
Last but not least, the storage section will be located at the rear of the motherboard tray, just like the power supply. Two 2.5″ and one 3.5″ slots are available.
Prices are €114.99 in black or white and €139.99 in black or white, but with aRGB fans.
Here’s the NZXT product sheet!
