Navi F240: two 240mm AIOs from SilentiumPC!
SilentiumPC announces the arrival of two all-in-one watercooling kits with its Navi F240. These are two 240mm AIOs, one of which has aRGB lighting on its fans. Now, what about the characteristics?
Navi F240: two AIOs signed SilentiumPC!
SilentiumPC Navi F240With these watercooling kits, the brand offers us two AIO in 240 mm relatively classic. The latter have a rather sober pump block with the logo of the brand on top. Underneath, we find a brushed copper base screwed. By the way, the compatibility of sockets, we can mention the LGA-1000 and LGA-2000 as well as the AM4.
The radiator features an aluminum construction with a total thickness of 28 mm. This block is connected to the pump via two 39 cm long pipes with a nice black sheath.
Regarding the ventilation, the kits land with two Fluctus 120 fans in 120 mm. Nevertheless, as usual with SilentiumPC, no data is communicated on the airflow and static pressure. However, we know that the mills operate from 300 RPM to 1800 RPM. As for the pump (by the way), it turbines from 1600 RPM to 2600 RPM.
Finally, the sale price is clearly accessible since the RGB version is 86 € against 75 € for the non-RGB. Note that the luminous version comes with a remote control.
Here is the SilentiumPC datasheet!
