N3 Mini: a Jonsbo enclosure for NAS with eight hard disks!
Following on from the N2, the Jonsbo brand offers us a new case: the N3 Mini. This is a PC case in the same vein as the N2, but slightly larger. In particular, it can accommodate up to eight 3.5″ hard disks!
N3 Mini: up to eight hard disks!
Jonsbo N3 MiniOnce again, we’re dealing with a small cube measuring 233 (W) x 262 (D) x 298 (H) mm. The weight is as contained as ever, with just 3.9 kg on the scales.
Inside, the most striking feature is the large storage capacity. Indeed, the lower part of the case features a total of eight baskets compatible with 3.5″ hard disks. These are hot-swappable, so disks can be added or removed on the fly!
Otherwise, configuration will be based on an ITX-format motherboard. You won’t need to be too greedy when it comes to the graphics card, as this model is only 250 mm long. The CPU cooling is 130 mm high, while the power supply is in SFX format.
Jonsbo N3 Mini
It’s a much more permissive version than the N2, all the more so as the ventilation can accommodate up to two 10 cm fans in the storage compartment. The motherboard section will benefit from two small 80 mm mills.
While the N2 costs €139.90 on Caseking.de, this N3 Mini is bound to be more expensive. Unfortunately, it is not yet listed in any store.
Click here for the Jonsbo product sheet!
