MX430 Mesh: a compact Cougar case that should breathe!
After the MX430 Air, here is the MX430 Mesh, a new version of the compact case from Cougar Gaming. The brand announces a version with a mesh front panel for a better air flow ? A different look? Or a lower price? It’s hard to say.
MX430 Mesh: compact and with a mesh front !
Cougar MX430 Mesh As a reminder, with this case, Cougar offers us a compact reference measuring 217 (W) x 371 (D) x 467 (H) mm. We will therefore find a support of the most classic for motherboards. The ATX being the biggest standard accepted in this model.
Otherwise, the space is generous for the CPU fans: 175 mm high. For the power supply, we have the right to a small 160 mm depth against 320 mm for the graphics card. Be careful here, because with a watercooling radiator on the front, this space decreases. Cougar MX430 Mesh This model has three aRGB fans installed as standard. However, the ventilation can be completed by adding a third fan in the front and two in the top. However, for watercooling radiators the compatibility stops at 280 mm maximum in the front and 240 mm in the top.
Once again, no selling price is known.
This way to the Cougar datasheet !
