MasterFrame: wood and stone fronts from Cooler Master
With its new MasterFrame 600 and 500 cases, Cooler Master was planning to launch a series of accessories to personalize the look of the cases. This is now underway, with the brand announcing wood and stone fronts. These will be available for the 500 and 600 models.
MasterFrame 500/600: wood and stone fronts!
When it comes to these fronts, the brand doesn’t do things like everyone else. While we usually find walnut or light oak, Cooler Master distinguishes itself here by using eucalyptus for the wood front. In contrast, the second front panel uses a material that is almost unheard of in the industry: stone!
On a MasterFrame 600, these front panels can be mounted… On the front, of course, but also on the top. With the 500 model, on the other hand, you can only replace the front panel, and that’s it.
As for dimensions, there’s no change between the wood and stone models. Both models measure 214 (W) x 443.25 (D) x 13.6 (H) mm. Finally, while the main materials remain wood or stone, a steel base is also available.
For the moment, prices have not been announced. All we know is that each model comes with a 2-year warranty.
Cooler Master product sheets here and here!
