LE Series: entry-level watercooling kits for DeepCool!
After having successfully launched its LS watercooling kits range, DeepCool is back in force with the LE Series. A new range oriented low price taking up most of the aesthetics of its high-end models. In short, let’s see what it says!
LE Series: entry-level watercooling kits!
DeepCool LE SeriesThis series of LE kits actually offers two variations, a first, basic one and a second one called ” Marrs” . In reality, there will be no significant difference between the two ranges, only the colors of the lighting, aRGB for one, cyan for the Marrs range. In any case, we find two kits with radiators in 120 mm and 240 mm, not 360 mm here. In terms of aesthetics (in front of the LS), we note that the pump is completely black and that there will be no mirror finish on the top. Also, no customization possible via a removable cover. Otherwise, in terms of ventilation, we find one or two aRGB fans in 120 mm. The characteristics are similar to the FC120 that we had with the LS720. On these new kits, we have mills operating at 2250 RPM maximum. The airflow will reach 85.85 CFM and the static pressure will rise to 3.27 mmAq. However, we do not know if the connection will be in series. We end by mentioning a pump that is not as fast as the one in the LS range. On these models, it works at 2400 RPM against 3100 RPM for the other model. We can therefore expect a lower performance… Nevertheless, the anti-leak system is still present in the radiator, which also seems to have a filling port. The prices, as we said, are very small since it will be necessary to count $59,99 in 240 mm against $49,99 in 120 mm.
Here and there DeepCool ‘s datasheets ! Here is our test of the LS720 !
