Jonsbo offers us a new case with the C6, a model with mesh panels. It is also very mobile with a carrying handle directly on top. What’s more, the price remains reasonable!
C6: Jonsbo’s mini transportable case!
With this little novelty, the Chinese brand offers us a case that is easily transportable due to the presence of a handle on top. In addition, the µATX format also helps with its compact dimensions: 202 (W) x 266 (D) x 295.2 (H) mm. The weight is not a hindrance either, with 2.3 kg on the scale.
Inside, space is limited, as the motherboard support stops at micro-ATX and mini-ITX. The power supply should not exceed 185 mm in length, while the cooling unit is limited to 75 mm in height. This is due to the location of the power supply: vertically, just in front of the CPU. As for the graphics card, it is 255 mm long.
In terms of storage, there is room for two 2.5″ SSDs or a 3.5″ hard drive. Otherwise, you will have to turn to the M.2 slots on your motherboard.
As for the ventilation, we will have a 120/140 mm slot at the top and bottom. On the front, we will be satisfied with a small 120 mm or a hard disk.
For the price, obviously, it should be around $105. Note that a white version is also available. You can also buy the case without the handle!
Click here for the Jonsbo datasheet!
