ID-Cooling unveils its IS-67-XT low-profile cooling unit
ID-Cooling presents its IS-67-XT Low Profile. It’s a reduced-size heatsink designed for compact configurations, such as ITX PCs.
IS-67-XT Low Profile: an ideal heatsink for small machines!
Ventirad ID-Cooling IS-67-XT Low ProfileIt measures 120 (W) x 120 (D) x 67 (H) mm and weighs just 500 g with fan.
The radiator features a top-flow profile with “C” heat pipes. There are six of these, measuring 6 mm in diameter. They are located on a nickel-plated copper base.
ID-Cooling IS-67-XT
Ventilation is provided by a single 120 mm fan. However, to gain height, it adopts a slim 15 mm thick format. In addition, it will be rather swift, with a speed range between 500 RPM and 2200 RPM. At full speed, airflow reaches 67.58 CFM, while static pressure rises to 1.54 mmH2O.
All that remains is to address the subject of compatibility. And in this respect, we know that it’s aimed at mainstream Intel and AMD platforms, with the possibility of mounting it on LGA-1700/1200/114X and AM5 as well as AM4.
As for the price, we’re talking about $44.99, with one version in white and the other in black.
Click here and here for ID-Cooling product sheets!
