A little tour in China with the brand Jonsbo which announces the arrival of two new all-in-one watercooling kits. Indeed, the brand unveils its HXW aRGB White, AIOÂ in 240 mm and 360 mm!
HXW aRGB White: two new watercooling kits in 240 mm and 360 mm!
This time, the brand satisfies white lovers with its two kits since we have both references in this color. As you can see, the pump, the fans and the radiator are white as snow. Moreover, the color is brought by a luminous lighting located on the fans as well as on the pump.
The radiator is as basic as it gets, with an aluminum construction and a standard thickness of 27 mm. On top, there are two or three 120 mm fans powered by PWM. The mills will operate from 900 RPM to 1800 RPM, generating an airflow of 85.4 CFM at full speed. However, nothing is said about the static pressure. Finally, we will retain the presence of a copper base at the pump.
Moreover, the pump, for its part, operates at 2500 RPM, no more indications as to its performance. Concerning the compatible platforms, we find the LGA-1700, LGA-1200, LGA-1100 and LGA-2000 in addition to theAM4/AM5 in AMD. Finally, as usual with Jonsbo, the selling price remains unknown.
Jonsbo ‘s datasheets are available here and here!
