From Jonsbo, we learn that the Chinese brand announces its HF1415. In fact, the company competes with Arctic on the field of slim fans. Indeed, with its new mill, the Chinese company offers a 140 mm slim model, a reference equivalent to the P14 Slim we talked about here.
HF1415 : a 140 x 15 mm fan !
In the program, we find a fan with a rather special profile since it is a 140 mm slim. In other words, its thickness goes from 25 mm to 14 mm. As we can see, the design remains sober with a smooth frame and we find square shapes on the edges. Of course, large silentblocks are present to reduce vibrations as much as possible … Just like the RGB lighting at the central hub.
Of course, it benefits from a PWM power supply and will work from 700 rpm to 1650 rpm… That is to say a rather restricted rotation range. However, at full speed, the air flow will be 75.59 CFM while the static pressure will reach 1.79 mmH2O.
Unfortunately, no selling price is announced, we will have to wait a little. As for the use, of course, it is rather particular since it will be useful only in case of lack of space above a motherboard for example.
Here and here are the Jonsbo datasheets!
