NZXT launches a new case on the market with the H510i All Might, a model featuring the peace symbol of the manga My Hero Academia. A new model with a very nice skin!
H510i All Might: turn your PC into a symbol of peace!
NZXT’s recipe is well known since the brand declines an already existing case and applies a very particular livery to it. This time, it concerns My Hero Academia with a case featuring All Might. As a reminder, All Might is the number 1 hero of the manga and is also nicknamed the symbol of peace!
As you can see, on this colorful case, the All Might skin is present everywhere. However, where it impresses the most is on the right side panel where it is represented in full! In short, a particularly successful case if you are a fan of the series.
Otherwise, the H510i is a rather compact mid-tower case. It will allow you to install a configuration with components measuring :
- 165 mm height for the CPU cooling unit
- 321 mm to 381 mm for the graphics card
- ATX power supplies.
The cooling part will accommodate up to four fans in 120 mm. As for watercooling, there is a radiator support in 280 mm max in front.
Before going to the price, note that this version has an integrated CAM controller. It will be able to manage the speed of the fan or the LED strips already integrated. Similarly, it will be possible to mount your graphics card vertically via two slots.
Finally, as for the price, you will have to pay $249.99 to afford it. Note that at this price, a Plus Ultra headset support is also included.
