Today, we are going to talk to you briefly about the Cougar coolers. Indeed, the Forza 50 and Forza 85 are back in the news since the brand releases a new press release. But what interests us are the prices sinceAmazon.com already references these two models!
Cougar, the price of the Forza 50 & 85 is known !
Before we talk about price, a little reminder of what these models offer us. The 50 model is the most compact version, with dimensions of 135 (W) x 75 (D) x 155 (H) mm. For comparison, the Forza 85 is 135 (W) x 110 (D) x 160 (H) mm. These larger dimensions are also felt on the weight which goes from 792g to 1160g.
On the heat sink side, we have a rather basic model for the 50 since it has only four heat pipes mounted in direct contact with the CPU. Similarly, its compact dimensions mean that we do not need an off-center base. On the other hand, the 85 is immediately stronger with its six heatpipes and its nickel-plated copper base, also eccentric.
In terms of ventilation, however, we have the right to the same mill, and this, regardless of the version. We find a MHP120 operating from 600 RPM to 2000 RPM. At full speed, the air flow will be 82.48 CFM and the static pressure, consequently, displays 4.24 mmH2O .
All that remains is to talk about the price, which can be found on Amazon.com, the AmericanAmazon Over there the price of the Forza 50 is $59.90 and the price of the Forza 85 is $69.90. The finish seems to be very neat with brushed aluminum, nickel plated heatpipes and caps on the end of the heatpipes.
Here and there are the technical data sheets of Cougar!
