FK120: DeepCool fan in 120 mm and without RGB!
DeepCool launches new fans on the market. On the program, we find the FK120, black 120mm fans, without RGB lighting. Mills that change a bit from the current productions if we can say.
FK120: black, lightless and sober fans!
DeepCool FK120With its new mills, DeepCool offers us something sober and pure. As you can see, the fan has a square frame with four large rubber pads. On their side, the blades are nine in number, quite wide and curved.
In terms of characteristics, the brand announces that the fan has a PWM type power supply. The speed range is then between 500 RPM and 1850 RPM. At full speed, the air flow generated will reach 68.99 CFM while the static pressure will rise to 2.19 mmAq.
We finish quickly with the selling prices which are rather soft. Indeed, it will be necessary to count some 11,99 € to the unit against 29,99 € the pack of three. Clearly, it is more interesting in pack, since the unit price is reduced to 9.99 € the piece… Especially since there will be no need for any controller to enjoy the lighting or otherwise.
Here is the DeepCool datasheet!
