A new all-in-one watercooling kit from TComas, with the Exit D3. With this kit, the brand proposes something original by integrating a trio of screens on top of the pump. Together, they form a stage on which a small figurine can be placed if required. As for price, it’s hard to say, but we’ll come back to that at the end of the article.
Exit D3: a TComas AIO with three screens!
A stage for figurines?
With this kit, the TComas brand offers us a highly original AIO whose concept is very similar to Tryx’s Stage. The three screens are positioned in the shape of a stage on which the user can place a miniature. The display is based on three 3.95″ screens with a resolution of 480×480.
Otherwise, the three screens can be managed independently. Via the brand’s software, the user can choose to display different videos on each screen, or screen the display on two screens. And let’s not forget that it will be possible to display system monitoring information such as CPU and GPU temperature, memory usage, component frequency, etc.
More concretely, this AIO features a heatsink that’s a little thicker than usual, with a 29.2 mm thick block. Ventilation is provided by three 120 mm mills operating at up to 3,000 rpm. At this speed, static pressure will reach 6.05 mmAq, a high pressure which, coupled with the high-speed mills, is likely to generate a fair amount of noise pollution. Last but not least, it’s compatible with Intel LGA-1700/1851 and AMD AM4/5 sockets.
Price :
As far as price is concerned, we’ll have to make do with the invoice in yuan: 1599. After conversion, that comes to ~€200. It remains to be seen how this will translate after import and any taxes. Another major question is availability. For the moment, it’s a kit distributed in China via the JD.com platform, but there’s no guarantee that the kit will land in Europe…
