TryX launches its AIO Stage!
Let’s take a look at TryX, which has just announced one of its latest innovations: Stage. Broadly speaking, this is a water cooling kit featuring a small platform surrounded by two screens designed to personalize and create scenes. You can display a figurine on the platform, for example.
Stage: an AIO that lets you create a personalized scene!
TryX Stage
To put it simply, the pump block has a rather original design, as it incorporates two 4″ screens. You can display whatever you want on these screens and configure them as an extended display or as two independent displays. On the base, you can choose to install a mirror or a matte base, depending on the desired effect, and use it to display a figurine. The screens act as a staging element! Beyond the staging aspect, TryX uses two IPS screens with a resolution of 720×720. The whole thing will also display 16.7 million colors while being managed by a dual-core CPU to avoid overloading the system’s resources.
For the rest, the brand has partnered with Asetek for the pump. The latter is advertised as managing a TDP of 280W. To achieve this, even if the flow rate or water column are not known, we do know that it will run at 2800 rpm at full speed.
As for the radiator, we find a 360 mm aluminum block. The dimensions are not specified, but we can expect it to be 27 mm thick.
The ventilation consists of three 120 mm fans. These are Rota SL ARGB fans, which will run at up to 1850 rpm. At full speed, the airflow will reach 65.64 CFM, while the static pressure will reach 2.49 mmAq.
Finally, we end with socket compatibility, which is limited to supporting mainstream platforms in LGA-1851/1700/1200/115x and AM4/AM5.
As for the retail price, this kit is expected to cost €239.90. Considering the concept and the presence of two screens, it’s not even that expensive. The brand could have been more greedy.
Check out the TryX product page here!
