Alphacool launches a new all-in-one watercooling kit in 360 mm. This new model is none other than the Eisbaer Pro HPE Aurora 360. This new version is equipped with a new radiator announced as more efficient!
Eisbaer Pro HPE: a new copper radiator for this AIO!
With this new model, the brand offers a kit in 360 mm with a new radiator. This time it is a NexXxos HPE Performance, a copper radiator of 30 mm thick with a fin density of 18 FPI.
On the pump side, we have the usual DC-LT2 of the brand. This one has an operating speed of 2600 rpm and a flow rate of 72 l/h. Of course, the base is made of nickel-plated copper. This base also has a large network of micro-fins of 0.4 mm thick spaced 0.4 mm. There are 58 of them and they cover a surface of 55 x 42 mm.
Cooling is provided by a trio of Aurora Rise fans in 120 mm. Powered by PWM, they have a rotation range between 0 rpm and 2500 rpm. At full speed, the airflow will be 118.9 m3/h (69.98 CFM after conversion) and the static pressure 3.17 mmH2O.
Of course, like any self-respecting Eisbaer kit, we have the right to a system of quick connectors allowing to combine several AIOs sharing the same system. We can then connect a kit Eiswolf to cool a graphics card for example.
The price of this model is 219.98 € on the brand’s store.
This way to the Alphacool datasheet!
