RTX 4090: Alphacool launches an AIO Eiswolf 2 for NVIDIA’s card!
Alphacool is already tackling the NVIDIA RTX 4090 with an all-in-one liquid cooling solution. If you know the brand, you already know what we are getting at! Yes, the brand already offers an Eiswolf 2 kit for the green team card!
RTX 4090: already an AIO Eiswolf 2 on the way!
Eiswolf 2 - RTX 4090
A version for MSI cards, for illustration
The basis of the kit is known since the time. Indeed, with each new iteration, the real novelty concerns, finally, the waterblock. Here, we find a NexXxos ST30 radiator in 360 mm and a thickness of 30 mm. Moreover, the latter is made of copper to improve thermal conductivity.
On top, we find a total of three Aurora Rise fans in 120 mm. These will operate from 0 RPM to 2500 RPM. The air flow will reach 119.8 m3/h and the static pressure generated will be 3.17 mmH2O.
To circulate the liquid, the brand exploits its famous pump, the DC-LT2 which grinds at 2600 RPM.
The waterblock is, as usual, of type full cover. It will cover the entire PCB of the card cooling GPU, memory and power supply stages. Its construction combines nickel-plated copper for the base and acrylic for the upper part. Finally, the cooling engine has 0.4 x 0.4 mm micro vials.
This model is therefore compatible with the RTX 4090 sharing a reference design. Nevertheless, the iChill X3 OC – X3 – Frostibe – Black models fromInno3D are also compatible. For the price, you will have to count 269,98 € !
Alphacool ‘s datasheet is here!
