Antec has announced the arrival of a new airflow-oriented case. The DP503 joins the brand’s catalog. On the program, mesh front and an interesting compatibility for what is the ventilation. We talk about a support of two mills of 185 mm in the front!
DP503: Up to nine fans possible!
In the program, we find a case measuring 220 (W) x 483 (D) x 492 (H) mm. Regarding the weight, we are at 7.88 kg, which is justified by the construction combining steel, plastic and tempered glass.
Inside, this model is spacious enough to accommodate a motherboard in E-ATX format at maximum. Otherwise, for the CPU fan, we have up to 170 mm against 205 mm for the power supply. Finally, the graphics card has 375 mm with, as a bonus, a small support, removable if necessary.
However, we will retain the possibility of installing up to nine fans in 120 mm. At the top and in front, we have three slots, against two on the power supply cover and one at the back. Otherwise, still on the front, we find two slots for fans in 185 mm or three in 140 mm.
For watercooling, we will have enough to mount 360 mm radiators at the top and front. Despite the triple 140 mm front support, 420 mm models are not supported, too bad. This time, we know its price positioning since Antec announces its case at $129.99!
