Cube Series : watercooling kits from Azza !
The Azza brand regales us with new products. The last time the brand offered us something, it was cases. This time, the company is showcasing two watercooling kits in 240 mm and 360 mm sizes. And here we have the Cube Series!
Cube Series: two watercooling kits from Azza!
Azza Cube 360The brand has announced two watercooling kits with 240 mm and 360 mm radiators. The latter are quite imposing, with a thickness of 35 mm. With today’s processors consuming more power and heating up faster, increasing the radiator’s thickness increases its heatsink surface and, consequently, its performance. However, the heatsink is still made of aluminum.
The pump is rather imposing, measuring 85 (W) x 78.5 (D) x 70 (H) mm. It will operate at up to 4000 rpm, with a flow rate of 96 l/h and a pressure of 1.5 mH2O.
Azza Cube Series 240 mm
Finally, ventilation is provided by two or three 120×25 mm fans. These will operate at up to 2000 rpm. At full speed, airflow will reach 65.2 CFM, while static pressure will rise to 1.8 mmH2O.
Clearly, this is a kit that relies on very pronounced aRGB lighting, as can be seen. The latter will be present on the fans as well as on the pump. The finish seems to have been meticulous, although the rivets are visible on the radiator’s edge, which is a shame…
… But given the prices, can you really blame the brand? The 360 mm kit is priced at $99.99, compared with $79.99 for the 240 mm. The only problem is that it’s exclusive to the USA. So if you’re an expatriate, why not?
Here are the Azza product sheets!
