Corsair introduces its Xeneon 34 QD-OLED display!
Corsair has added a new screen to its range with the Xeneon 34 QD-OLED, whose full name is : 34WQHD240-C. This is a top-of-the-range reference featuring a latest-generation OLED panel from Samsung!
Xeneon 34 QD-OLED: Minimum Wage !
Corsair Xeneon 34 QD-OLEDThe brand is offering us a massive monitor with a 34″ QD-OLED panel. It’s also curved at 1800R, so the curvature isn’t too pronounced. Naturally, the display has a 21:9 resolution, 3440×1440 to be precise. It is also highly responsive, with a frequency of 240 Hz and a latency of 0.03 ms. It is also NVIDIA G-Sync and AMD FreeSync Premium compatible.
The advantage of QD-OLED panels lies in their high contrast ratios, and this model is no exception with its 1,500,000:1 ratio. As for brightness, it can reach 1,000 nits at peak and 99% coverage of the DCI-P3 colour gamut. In short, all this contributes to its DisplayHDR True Black 400 certification.
For settings, there’s no need to press any buttons to display the OSD, as this model has a proximity sensor. All you have to do is bring your hand close to the screen to display the menu. Finally, although it has an adjustable stand, this screen comes with a 100×100 VESA mount for mounting on an articulated arm, for example.
Finally, the connectivity features two HDMI 2.1 ports, a DisplayPort 1.4 and a USB-C DP ALT offering 65W of power on one side. On the other, there are four USB-A 3.1 with KVM, a USB-C 3.1 upstream in 15W and a headphone socket. The screen’s internal power supply means you won’t have a brick to try and stow somewhere under your desk.
In short, this is a very nice reference that costs the equivalent of a French minimum wage: €1,349.99. Pre-orders are now open, with deliveries scheduled for 6 September.
Here’s the Corsair product sheet!
