Cooler Master also unveils its Halo² fans!
Cooler Master offers us new fans with its Halo², models in 120/140 mm. They are also available in white or black with a rather present aRGB lighting. Moreover, it is this fan that we find on the Hyper 212 Halo Edition.
Halo²: new fans signed Cooler Master!
Cooler Master MF120 Halo²With these fans, the brand offers models in 120 mm and 140 mm. They are also available in two colors with white or black models. What to suit a majority of users.
With these fans, Cooler Master highlights the use of rubber silentblocks to reduce vibration. The same goes for the blades, which have been widened by 10% to improve performance.
In any case, we have fans that work via a PWM signal. They also have a speed range between 0 rpm and 2050 rpm in 120 mm. In 140 mm, they are a bit slower: from 0 rpm to 1600 rpm. The rest of the features indicate:
  • 120 mm:
    • Airflow: 51.88 CFM
    • Static pressure: 2.89 mmH2O
  • 140 mm :
    • Airflow: 59.51 CFM
    • Static pressure: 2.53 mmH2O
For the prices, you should know that Cooler Master officially announces the model in 120 mm around 16€ against 19€ for the version in 140 mm. Specifically, we find the 120 mm around 19€ against 21€ for the 140 mm.
Here and there the technical data sheets of Cooler Master!
