NZXT has just unveiled its new H7 Flow PC case at Computex 2024. The brand draws inspiration from dual-chamber case designs to maximize internal airflow. NZXT’s trick is to position the power supply vertically, enabling the use of 3 x 120mm fans at the base of the chassis, drawing cold air underneath the case and pushing it upwards. Add to this a wide-open front panel that can accommodate up to 4 140mm fans, and you get an idea of the chassis’ potential.
A 360mm radiator can be fitted to the top of the case, but if that’s not enough, you’ll have to fall back on the front panel we mentioned earlier. Here, you can fit a 420mm radiator. All this is achieved in a box of classic dimensions, which is appreciable.
Features of the NZXT H7 Flow :
- The redesigned case interior features a vertically oriented PSU layout, allowing the installation of 3 bottom-mounted fans of 120 mm each to provide direct airflow to the GPU.
- The case is supplied with 3 front-mounted 120 mm fans for ready-to-use cooling
- This chassis can accept radiators up to 420 mm at the front and 360 mm at the top for ultimate liquid cooling potential.
- High-performance mesh panels maximize airflow and filter out dust.
- Tool-free access to front, top and side panels with an intuitive cable management system facilitates construction and upgrading.
NZXT is announcing the arrival of this case in black and white during the month of June. There will also be a version with and without RGB. The non-RGB version should sell for around €139, compared with €159 for the RGB version.
