ASRock launches its 4X4 BOX 7000/D5 mini PC based on Ryzen APU
For the blow, the industrial branch of ASRock announces the arrival of two new mini PC. These are none other than the 4X4 BOX 7000/D5 of the brand. They are equipped with a DDR5 memory slot in SO-DIMM format as well as a Ryzen 7 or Ryzen 5 APU!
4X4 BOX 7000/D5 : ASRock mini PCs equipped with RyzenAPU!
ASRock 4X4 Box 7000/D5ASRock Industrial offers two mini machines with very compact dimensions. These PCs measure 110 (W) x 117.5 (D) x 47.85 (H) mm. Moreover, via a VESA support, we can save even more space by mounting them behind the screen.
Internally, we will have the right to two DDR5 memory slots in SO-DIMM format. They will be able to take up to 64 GB of RAM at a frequency of 4800 MT/s. Otherwise, as far as the storage part is concerned, we have an M.2 slot for the installation of SSDs (2242/2260/2280). In addition, a SATA III is also present!
Regarding the APU, we have two configurations, one with a Ryzen 7 7735U, the other with a Ryzen 5 7535U. In fact, these are CPUs intended for the laptop world. However, this does not prevent them from being equipped with 8c/16t and 6c/12t respectively. And as for the frequencies, they show 2.7 GHz/4.75 GHz (base/boost) for the Ryzen 7 against 2.9 GHz/4.55 GHz (base/boost) for the Ryzen 5.
Finally, the graphics part will support resolutions up to 7680×4320 in 60 Hz via HDMI 2.1. In DisplayPort 1.4a, it will have to be satisfied with a maximum resolution of 4096×2160 in 60 Hz.
For the price, we will have to wait a little longer!
Here and there the technical data sheets of ASRock Industrial !
