Singularity Computers continues to expand its external watercooling range with a 360mm version of its Arterial system. Called the Arterial 2 360mm, this open radiator support offers much more than a simple base.
External watercooling?
At Singularity Computers, the Arterial range corresponds to a set of systems designed to accommodate external custom watercooling components. This type of independent solution, popularized by Watercool and its famous MO-RA, has many advantages. First and foremost, it can drastically increase the cooling capacity of a configuration. We’re thinking here of small cases, but also of certain minimalist test tables. It offers the possibility to remove the liquid risk from the precious components.
External watercooling is becoming increasingly popular. Beyond its practical aspects, some are turning it into an art form in its own right, and are constantly reinventing it. It’s impossible not to mention LiquidHaus ‘ EXT stands and, more recently, Singularity‘s Arterials. Initially available in the form of water boxes, led by an oversized 2 x 560mm, the range is becoming ever more open. Here is the 360mm version, the most widespread format in the field.
ARTERIAL 2 360mm: a complete system
Singularity Computers has decided to set itself apart on two counts:
- the brand’s inimitable look
- the completeness of the system, bordering on plug & play.
So, in addition to the 360mm radiator support, compatible with push-pull fans, the Arterial comes with :
- integrated PCB
- aRGB lighting
- reservoir and distribution plate
- slots for two D5 pumps
- HUB with temperature-based settings and manual control for fans and pumps
Nothing is missing. All that remains is to connect the structure to a configuration with quick disconnects, power the HUB via a dedicated power supply or an extension cable, and the loop is operational.
The 360mmArterial 2 is available from the manufacturer’s website for 250€.
