Arch Q503: a Seasonic box compatible with CONNECT
For the cable management, several solutions are available. Either you have to wire your case normally, or you turn to Gigabyte’s Project Stealth (or MSI’s equivalent) or you choose the Arch Q503 from Seasonic. We are talking about a PC case compatible with the CONNECT module of the brand!
Arch Q503 : a case with cable splitter for Seasonic !
Seasonic Arch Q503In the program, we have the right to a pretty baby in medium tower format displaying 215 (W) x 448 (D) x 482 (H) mm. Internally, we will be able to install the motherboard in E-ATX format to the maximum. The rest of the components are not left out with 380 mm for the GPU, 165 mm for the heatsink and 230 mm for the power supply.
In terms of ventilation, the case offers a number of slots in 120 mm. Indeed, it will be possible to integrate up to eight fans: three in the front, two in the top, one in the back and two on the power supply cover. For 140 mm, however, four slots are available. For watercooling, this model will support a maximum of 360mm and 280mm radiators.
However, what interests us most is the compatibility with the CONNECT module. As a reminder, this famous module simplifies the wiring by distributing the connectors to strategic places in the box. You should know that in this model, there will be enough space to integrate it without any problem.
Finally, the selling price is still unknown.
Here is the Seasonic datasheet !
