AK620 White: DeepCool’s compact dual-tower heatsink hood goes white
At the end of 2021, DeepCool announced the arrival of a new dual tower heatsink on the market. It was the AK620, a compact model offered in black. This time, the brand is highlighting a new color, white, with its AK620 White.
AK620 White: DeepCool’s heatsink goes to the bench!
DeepCool AK620 WhiteThis new heatsink is based on its black counterpart. We find a heatsink with two cooling towers. In terms of dimensions, this translates into 129 (W) x 138 (D) x 160 (H) mm with the fans. On the scale, we will have a rather heavy set showing 1456 g all the same!
Beside that, we find a rather classic structure with a total of six copper heat pipes joining at the level of a copper base. The latter is nickel-plated, but does not offer a mirror finish.
The ventilation, on the other hand, is entrusted to two 120 mm fans powered by PWM. Their speed range is between 500 RPM and 1850 RPM. At full speed, the air flow generated will be 68.99 CFM and the static pressure will reach 2.19 mmAq.
Of course, we find all the small attentions that we already have on the AK400. Thus, the cooling towers have a top cover while the fins resume their characteristic waffle shape.
Finally, as far as socket compatibility is concerned, we find the AM4 in AMD. In Intel, the LGA-2000 makes its appearance, unlike the AK400, while remaining compatible with the LGA-1000.
For the price, it will be necessary to count ~80 € at LDLC.
This way to the DeepCool datasheet!
