VR3: a vertical ITX case with mesh at Jonsbo!
The Chinese Jonsbo announces the arrival of a new case in its catalog. The brand offers a model in ITX format with mesh panels, all with a vertical design. In short, here is the VR3 of the brand.
VR3: mesh and vertical design at Jonsbo!
Jonsbo VR3With this new product, Jonsbo offers us a reference with dimensions of 255 (W) x 204 (D) x 382 (H) mm. The weight is also light with 5.28 kg, which is justified by the format of this model.
Inside, we can only install a motherboard in mini-ITX format. However, the graphics card will be able to reach a length of 325 mm. As for the CPU cooling unit, we have a space of 70 mm, so we will be satisfied with a so-called top flow heatsink… Or all-in-one watercooling in 240/280 mm in front. Finally, an SFX or ATX power supply (14 cm deep) will fit.
We finish quickly with the storage which has two 2.5″ slots and/or two 3.5″ slots. In this case, the length of the graphics card will have to be trimmed: 185 mm max.
For the moment, the price is not yet known, however, you should know that a PCIe 3.0 riser will be supplied with the purchase. Finally, this model reminds us strongly of the Meshlicious of Ssupd both in its conception and its design.
Jonsbo’s datasheet is here!
