Vortex View: Antec finally announces its swivel-mounted AIO!
The Vortex View 360 is an all-in-one water cooling kit from Antec that is coming soon. It features a pivot-mounted screen, but more importantly, it marks a new collaboration with Asetek. In short, this kit was on display at Computex last year (end of May 2025), so it has been known about for almost a year, but Antec is only launching it now.
Vortex View 360: the result of a new collaboration with Asetek!
Antec Vortex View
With this kit, Antec has partnered with Asetek, which it has selected as the OEM for the pump in particular. Antec provides the fans and the pump design, which is completely original. The pump features a large (5″) pivot-mounted screen that can be rotated 360°. The position is locked by tightening a ring mounted on the pump cover.
The screen has a resolution of 720p, all at a frequency of 60 Hz via a small IPS panel. The brightness is good at 300 nits. At the rear, just like the Hyte Thicc Q60, there are aRGB LEDs, while the screen can be used to display whatever you want. For easy connection, Antec provides a USB 3.0 hub that plugs into your motherboard header.
The radiator, in the images shared by the brand, has a basic finish with rounded edges and visible rivets. Finally, it is constructed from aluminum and has a standard thickness of 27 mm.
Ventilation is provided by three fans that will run at up to 2000 rpm. When running at full speed, these fans will generate an airflow of 59.23 CFM, while the static pressure will reach 2.46 mmH2O.
As for installation, it is compatible with LGA-115x/1200/1700/1851 and AM4/AM5 sockets.
In terms of price, it costs €279.99, which is not cheap, but the kit does try something different with its display.
Check out Antec’s product page here!
