New case for the Thermaltake brand which announces its Versa T26 TG ARGB model. As we will see, it is a rather original model because of its front panel which combines mesh and tempered glass.
Versa T26: four mesh panels and tempered glass for the front panel!
With this model, Thermaltake puts forward a case with a front divided into four panels. These panels are made of metal mesh and tempered glass. The result is really original, it remains to be seen what impact this will have on the airflow.
Beside that, we find a medium tower model quite classic measuring: 225 (W) x 464.2 (D) x 485 (H) mm. The weight is 8.21 kg.
Internally, it will be possible to install a large motherboard that can go up to E-ATX. The rest of the components is not left out with :
- 175 mm height for the CPU cooling unit
- 350 mm length for the graphics card
- 200 mm for the power supply (160 mm with the HDD cage in place)
On the other hand, the storage part remains quite basic since it stages a cage of two baskets compatible 3.5″/2.5″. It is also completed by two 2.5″ trays at the back of the motherboard tray.
The ventilation can be consequent since there are up to seven slots for the fan in 120 mm. In 140 mm, we lose a slot with six mills maximum. However, this leaves us enough space to install a 360/280 mm radiator at the top and front of the case!
For the moment, the selling price is not known yet, patience, patience…
This way to the Thermaltake datasheet !
