Thermaltake announces the arrival of a new cooler with the UX 210 aRGB. A new aircooling fan that comes in a 120 mm format. Moreover, there is no surprise if we tell you that it is equipped with an aRGB fan ?
UX 210 aRGB: RGB and five copper heatpipes for TT’s ventirad!
With this new model, the Thermaltake brand announces a relatively compact heatsink. In fact, it will have dimensions of 136 (W) x 74 (D) x 153 (H) mm which will allow it to be installed in almost any case.
Otherwise, the radiator has a nickel-plated copper base with a mirror finish. From this base there are a total of five copper heat pipes, also nickel-plated, each with a diameter of 6 mm. Of course, they pass through a stack of aluminum fins.
The ventilation is provided by a 120 mm mill with RGB lighting on its central hub. Powered by PWM, this fan has an operating range between 600 RPM and 2000 RPM. At full speed, the airflow will rise to 72.3 CFM and the static pressure will reach 2.31 mmH2O.
Finally, as far as socket compatibility is concerned, we find the AM4, AM3 (and derivatives). In Intel, the LGA-2000, LGA-1700 and other LGA-1100 are present.
As usual, we will have to wait before knowing the price.
Here is the datasheet of Thermaltake !
