Biostar is one of the few manufacturers that always offers new motherboards for cryptocurrency miners. This time, it’s about the TZ590-BTC, a board equipped with nine PCIe!
TZ590-BTC : a motherboard that can host up to nine graphic cards !
This new card comes in a classic format, since we are dealing with a reference in ATX format. Gone are the references measuring 1 km long like the H510 Pro BTC+ for example. In case of stopping the activity, the card can be recycled in a more classic machine.
Otherwise, this model features an Intel LGA-1200 socket and a Z590 chipset, so the card is ready for the 10th and 11th generation Core i. Also, on the RAM side, we have four DDR4 slots for 128 GB of memory at 3600 MT/s.
However, what interests us most here are the PCIe connectors, of which there are nine. There are eight small PCIe x1 3.0 and a single PCIe 4.0 x16. Of course, if you want to set up a mining configuration, you will have to use risers.
Apart from that, we are dealing with a rather well-equipped model since it displays six SATA connectors as well as an M.2. We will also have the right to a network part in Realtek ALC887 and network in Intel I219V. At the back, there are no less than six USB and VGA and HDMI outputs. Finally, the power supply displays two 24-pin ATX connectors and an 8-pin EPS12V.
Once again, no price is given. Nevertheless, the card is rather complete for a model intended for mining, we have seen much more refined than that.
This way to the Biostar datasheet!
