Trofeo Vision, a Thermalright AIO with a 6.86″ screen!
Bigger and bigger – that’s how you could sum up the size of the screens found on all-in-one watercooling kits. Indeed, in the space of a few years, we’ve gone from a small screen cleverly integrated into the pump cover to large models mounted right on top. With the Trofeo Vision 360, Thermalright offers just such a product, with an imposing 6.86″ screen!
Trofeo Vision 360: a 6.86″ screen!
Thermalright Trofeo Vision 360Thermalright’s new AIO features an imposing LCD screen mounted on the pump cover. This IPS-type screen boasts a diagonal measurement of 6.86″ and a resolution of 1280×480. Clearly, there’s plenty to do on the display front. It remains to be seen whether the software will follow suit in terms of functionality to exploit the full potential of this model. In any case, we find a 27mm-thick aluminum radiator. Nonetheless, the finish appears to be quite good, with an attractive matte black paint finish lined with sides that are not devoid of visible rivets. This block is topped by three 120 mm TL-UB36 fans, models operating at up to 2150 rpm. At full speed, they will generate an airflow of 69 CFM, while static pressure will reach 2.87 mmH2O. As for the pump, although we have no information concerning its flow rate or water column, we do know that it will run fast. The manufacturer claims a high operating speed of 6400 rpm. The big question is whether or not it will be noisy in operation. As for socket compatibility, it can be mounted on mainstream AMD and Intel platforms. As for price, Thermalright is obviously very aggressive. At Computex, a manager told us that they own their own factory, which means they can control production from A to Z. Expect to pay 899 yuan (approx. €110), with a 6-year warranty!
Thermalright Trofeo Vision 360!
